Advice Re: Indoor Deck/floor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-14-2013, 12:55 PM   #1
ghh
Advice re: indoor deck/floor
I need some advice on an indoor deck/floor I'm wanting to build inside my metal shed. Shed dimensions are 72x42x18 feet (lxwxh) Floor/ deck surface will be 42 ft by 12 ft. The surface of the deck will be 9 feet above the dirt floor of the metal shed. The building has vertical wooden posts every 7 feet along the walls, and the deck/ flooring will be up against the shed walls on three sides ( both 12 foot sides and a 42 foot side. ). Im planning one set of five foot wide stairs going up.
At first, I thought I'd build it similarly to an outside deck, but then I thought that maybe I could do better given that it won't be exposed to the elements. So I would really appreciate input as to how to best accomplish the following goals:
Goals:
1.) I'm building this for storage
2.) I'd rather overbuild for strength/durability but I have no idea what that actually means in terms of specifics
3.) what are advantages/ disadvantages of building it as a deck vs using plywood as the flooring surface? For instance - would a deck of this size (500sq feet) be cheaper/ stronger using 3/4 inch plywood/osb or would using decking with gaps between the decking be good enough.
I would really appreciate any/all input
Thanks.
Greg
ghh is offline   Reply With Quote
Advice is not always correct! Docwhitley Plumbing 9 02-14-2011 10:12 PM
Chain link fence install advice ponch37300 Landscaping & Lawn Care 1 11-10-2010 07:08 PM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 11:05 AM
looking for Serious advice and Help on Insulation bfan781 Building & Construction 6 05-19-2010 12:02 PM
Electrical Advice Caution!!! Mike Swearingen Electrical 12 03-05-2008 12:51 PM
