Advice On Purchase Of A Pancake Compressor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-11-2007, 08:58 PM   #1
Advice on purchase of a pancake compressor
I'm considering purchasing a Porter-Cable pancake compresser for installing crown molding, baseboard, chair rail, etc.. It comes with 3 nail guns and is rated at 150psi. I believe it is a 5 gallon tank. Will this be sufficient and will it handle a framing nailer?
joe3534 is offline   Reply With Quote
Old 04-11-2007, 09:35 PM   #2
I can tell you that it most definetly will. I purchased the kit you have about 4 years ago and it works great. About 2 years ago I purchased the Porter Cable F350 framing nailer and I used it to build a shed. Right now I am using it to finish my basement. I've put about 4000 nails through it and both the compressor and gun are great. The compressor cycles on about after 20 framing nails are shot. Don't know where I would be without either of them.
handyflyer is offline   Reply With Quote
Old 04-11-2007, 09:48 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Yes, it will...
- Build Well -
Old 04-11-2007, 11:53 PM   #4
Rewards Points: 1,088
Yes, but very noisy and compressor will click on often since the tank is small.
handy man88 is offline   Reply With Quote
Old 04-12-2007, 01:26 PM   #5
Easy, fix.....Put the compressor in another room, use 50-100 ft. hose = nice and quite.
- Build Well -
Old 04-12-2007, 01:38 PM   #6
Yes, but you'll experience a pressure drop due to the increase in hose length. Compressor will have to work even harder.
Old 04-12-2007, 02:03 PM   #7
I've seen that kit -- go for it -- you'll love it. I also have a PC350 framing hammer and run it with a pancake compressor - no problem. I don't know how I did anything before I had all my guns.
mikim is offline   Reply With Quote
Old 04-12-2007, 02:28 PM   #8
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,284
That's the one that I have. I don't know why I waited so long to buy one. It passed my sawzall as my favorite tool. I've got the Makita AN922 framing nailer and it keeps up with that. I would imagine if I were driving a lot of nails at once like when siding a house, I might need to let it catch up, though. Another nailer that I think is a must-have is a palm nailer. I've got the cheapo Grizzly ($19.99) and it will drive 20d in a second.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
The Following User Says Thank You to Clutchcargo For This Useful Post:
RickyG (05-24-2011)
Old 04-12-2007, 02:43 PM   #9
...and ?
All we use are 100' hoses on our framing jobs. For one DIY person to run one framer on their project using such a compressor and 100' hose is not that demanding.
It's not the same as the pace that we run 3 + framers with rapid bump firing on a large project, for which we use a different larger oil fed compressor with larger tanks.
Really, that pancake compressor can take it.
We have one of those exact same model compressors. We use it in the cold months (no oil) to do smaller jobs. We have had it for 5 years = no problems at all keeping up with a single framer (aimed firing) on a 100' hose. Ours is pretty beat up, but it keeps going....
- Build Well -
Old 04-12-2007, 03:04 PM   #10
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
Never heard of pressure drop when using longer hoses. I have heard that a compressor cycles a little less often because of extra volume of air. Whatever.
Anyway - What the others said. The PC compressor will be fine for your use.
You may also want to consider the new Makita compressors. They are significantly quieter.
Here are a few links.
http://www.makita.com/menu.php?pg=pr...det&tag=MAC700
and
http://www.makita.com/menu.php?pg=pr...et&tag=MAC2400
One friend has the small one, another has the dual tank. Every time I hear them kick on I am amazed!
Brik is offline   Reply With Quote
Old 04-12-2007, 03:47 PM   #11
Originally Posted by AtlanticWBConst. View Post
...and ?
My point was that since it's going to have to work harder due to the longer length of hose, that means the compressor will fire off more than usual even though you have it in another room. Using it on a construction site is no problem, but using it in a home where the windows and doors are closed is like a sudden jolt. You're a full time contractor, so you're probably used to hearing compressors firing off. For the homeowner DIY'er, it gets annoying after awhile.
Old 04-12-2007, 03:49 PM   #12
and
If only they came in a kit, I'd get the quieter ones in a heartbeat. I currently have the pancake compressor one from PC. Quieter ones may be better for the DIY'er because the DIY'er could be doing work at all hours of the day during his free time, and that could mean when the family is sleeping.
Old 04-12-2007, 03:57 PM   #13
Handyguy
Brik's Avatar
Ah, they DO come in a kit!
http://www.makita.com/menu.php?pg=pr...t&tag=MAC700K2
and
http://www.makita.com/menu.php?pg=pr...t&tag=MAC700K1
and
http://www.makita.com/menu.php?pg=pr...t&tag=MAC700K3
Old 04-12-2007, 04:23 PM   #14
Nice. Price?
Unfortunately, HD and Lowe's hardly carry the nice Makita tools.
Old 04-12-2007, 04:55 PM   #15
Handyguy
Brik's Avatar
Do I need to do all the work???
From Amazon
MAC700 $159
MAC2400 $259
MAC700k1 $252 toolbarn
I may eventually get one of these compressors. I'm set with nailers. I got a several recon porter cable nailers and they have been excellent.
Air compressor and framing nailer for DIY ADKstorm Tools 20 11-11-2010 08:38 AM
Is this air compressor worth it? Biggredd Tools 11 09-18-2009 05:36 PM
Replacing Wiring From Outside Fuse Box To Central Ac Compressor bobo Electrical 8 03-02-2007 10:23 PM
Heat Pump compressor trips circuit breaker joejean HVAC 3 08-28-2006 01:15 PM
Looking for last minute advice daveincincy HVAC 4 04-22-2006 07:15 PM
