Advice If Stairs Will Self Support? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-04-2012, 08:57 PM   #1
Advice if stairs will self support?
Hello;
I have a finished basement which is accessed by stairs which have a finished sheetrock wall on one side as shown in picture. I would like to build a finished storage area under the stairs which will require the removal of the 2 x 4 studs that hold the sheetrock face. The stair treads are routed into the sides of 1 x 12s which are secured with wedges (see pic).
My question is if the stair construction can be self supporting if the 2 x 4 framing is removed? The stair construction seems to have been built with good quality methods (late 70's construction) and typically I thought stairs would be built without the reliance on vertical framing to maintain it's safe useage.
Thanks for your advice.
Dave
Advice if stairs will self support?-resampled_2012-07-04_19-42-52_92.jpg   Advice if stairs will self support?-resampled_2012-07-04_19-40-54_352.jpg
dmarkie is offline   Reply With Quote
Old 07-04-2012, 09:39 PM   #2
Rewards Points: 13,256
The 2 X's where there just to hold up the sheet rock.
If your going to open up that area 5/8 sheetrock will need to be installed under the stringers to meet code.
Old 07-05-2012, 05:16 PM   #3
Thanks Joe for the advice. So 1x 12 stringers are adequate to supporting the stairs by themselves. Most basement stairs that i've seen (i'm not a builder) were more often 2 x something stringers. That's good and yes i plan to sheet rock the opened up area.
Thank You.
Beadboard Wainscoting Down Stairs jimmycrackcode Carpentry 5 02-08-2012 03:21 PM
Help with staining my stairs kimber Flooring 2 12-04-2009 08:45 PM
Painted the stairs ... . kimber Painting 8 10-07-2009 12:50 PM
cream trim downstairs, white trim upstairs, advice for stairs? allyr Painting 1 09-26-2009 05:01 PM
Guidance needed for deck support posts Mike Loyd Building & Construction 4 08-23-2009 08:03 PM
