Advice Extending Ridgeline Of Ranch House - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-04-2011, 10:13 PM   #1
Advice extending ridgeline of ranch house
I have a rectangular ranch house with very simple ridge board/rafter construction like the one pictured here:
http://www.shedking.net/ridge-beam.html
In order to make our master bath larger, I'm considering extending the house by about three feet. the only thing on that end of the house is the bath and two car garage. My question is, what is the best way to tie into the existing ridge board and extend it the necessary three feet? Can the 3 foot extension just be butted against the existing ridge board? Like in this photo? http://www.matthewghunter.com/IMG_2515_20.jpg
The rest seems pretty straightforward, but any advice on potential difficulties would be appreciated.
Many thanks!
Russell
pfau is offline   Reply With Quote
Old 02-04-2011, 11:31 PM   #2
Registered User
Rewards Points: 526
It would depend entirely on your local Building Department. You would need a permit for this to meet the very minimum safety (Code) for your H.O. Insurance and if you ever sell the house.
Gary
Old 02-05-2011, 03:17 AM   #3
Contractor - Renovations
fungku's Avatar
i think with a supported ridge beam like in the first photo you may need an engineer, especially if you want to add a splice or joint.
(remember this is a beam)
The first photo is incorrect anyway. he forgot the support for the ridge beam.
the one in the second photo is likely a ridge board, and if that is what you have. (do you have ceiling joists?) then it should be able to be done like in the second photo. though you may have to get creative on how you do your temporary support of the rafters while you redo the ridge...?
where are you located?
fungku is offline   Reply With Quote
Old 02-05-2011, 08:12 AM   #4
clarification and photos
Thanks for the replies. I just learned the difference between ridge board and ridge beam by reading some of the other discussions on this board. I'm pretty sure this is indeed a ridge board as there are rafters and angled supports from rafters to joists. I also got the bright idea to get in the attic to see how the builder did it (I didn't think there would be one solid length board all the way from one end of the house to the other!). Sure enough, I answered my own question as there is a simple butt joint up there. See photos here:
https://picasaweb.google.com/rspfau/...eat=directlink
The ridge board should support itself while I make the extension, shouldn't it?
Many thanks!!
Russell
Old 02-05-2011, 08:18 AM   #5
In fact, I think I'd just double up my rafters at that butt joint...leaving the original (end rafter) in place and installing the first new rafter up against the original and nailed to the end of the new ridge board extension. That way I'd not have to tear apart any of the original construction.
I'm in Texas....outside of the city limits.
-Russell
Old 02-05-2011, 08:38 AM   #6
Framing Contractor
Many thanks!
Russell
How wide is the existing house?
Are you keeping the existing rafters and wall?
Are you just making small openings in the wall to get to the 3' addition?
Since you're adding 3' to the addition, the ridge will only extend 1'6" if you want to keep the same pitch. You don't even have to extend the ridge if you're not worried about keeping the same pitch. You can just nail the new rafters into the existing ridge.
Are you drawing the plans to present to the town for permits and inspections, or do you need an architect or engineer for this? Where I'm from homeowners can draw their own plans to get approvals for permits.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 02-05-2011, 10:01 AM   #7
plans
I added rough plans to the link:
https://picasaweb.google.com/lh/phot...eat=directlink
Orange and green are existing bath and garage respectively. Black are existing ridge board/rafters. Yellow and light green represent the added space to bath and garage (the existing exterior wall will be knocked out so that the bath is a single, larger room). Red indicates new rafters/ridge board.
The house is 36' wide at the side to be extended (it's a two car garage with entrance at the side...I'll have to reframe the garage door).
I'm out in the country in Texas, so I'm pretty sure there aren't any building restrictions...but I'll do whatever is necessary to do things right and by the rules.
Old 02-05-2011, 10:08 AM   #8
Framing Contractor
I misunderstood what you were doing. I thought you were making the house wider by 3' from 36' to 39'. Sorry about that.
Yes, you can that's house it's always done when you have ceiling joists and a ridge. If it were to be cathedral, you would need a ridge beam and that beam would have to go inside that wall cutting the existing ridge back depending on whether the ridge beam was dropped or flush.
Joe Carola
Porch has shifted on a house I am considering buying. Need advice ryanclemson Building & Construction 4 01-31-2011 08:30 PM
Old house new problems: I need advice SandyD Building & Construction 3 09-14-2007 10:53 PM
Buying house... Need advice! sweetsue777 General DIY Discussions 9 01-02-2007 04:11 AM
Need advice and assurance on house issues! Leikela General DIY Discussions 3 12-04-2006 10:10 PM
Need advice...rotten floor joists on house I'm buying strngelitlgrrl General DIY Discussions 5 08-01-2005 09:14 PM
