Advice On Closing In Hole In Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-29-2010, 02:37 PM   #1
Rewards Points: 12
Advice on closing in hole in wall
I'm taking out a wall AC unit, and I want to close in the hole (16"x25") in the CBS wall. I planned on cutting the blocks to size and mudding them in. Anything else I need to think about, or is there an easier way?
TIA
pianodude is offline   Reply With Quote
Old 06-29-2010, 04:09 PM   #2
Rewards Points: 4,656
cardboard & glue's easier but you've picked the right method jomama uses foam-in-a-can but he also uses hair-in-a-can, too
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Fill hole in foundation wall after Gas line was removed ctbfalcon Building & Construction 2 05-03-2010 08:16 AM
Hole in Cinder Block Wall for Small Air Conditioner stevehgraham Building & Construction 1 02-20-2009 06:31 AM
Hole in new construction basement wall AprilQ Building & Construction 5 07-08-2008 06:14 PM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 10:28 AM
