Old 03-05-2010, 12:59 PM   #1
Advice on building a wall
Hi all, I live in an old apartment block on the 4th floor. At the back is what used to be a little balcony with a wall about 1 metre high. This balcony has since been enclosed and incorporated into the kitchen. Now I have a damp/condensation problem, partly because this wall was never designed to be interior and is only single skin (10 cm thick). What is the best way of making this a 'proper' wall? I would like something not too thick (to minimise the amount of space I'll lose in the kitchen), yet still solving the damp problem. Lightweight materials would be best as I'll have to carry whatever materials I buy up 4 flights of stairs! Should I go cavity wall (with insulation?) or just build a second skin of concrete blocks? Obviously I'll be removing the radiator and pipes! Thanks for any advice.
Robbo71 is offline   Reply With Quote
Old 03-05-2010, 01:04 PM   #2
Xtreme DIY'r
Where are you located ?
This is an Apt & you are building a wall ?
Old 03-05-2010, 01:35 PM   #3
Hi Scuba Dave - I'm over the pond in Europe. The floors between the apartments are concrete. I don't envisage any problem as regards the extra weight.
Old 03-05-2010, 03:08 PM   #4
Robbo London,Manchester?
I know England has some pretty strict building codes.
Please make sure you build to any code...
Good luck and or cheers
lemon714 is offline   Reply With Quote
Old 03-05-2010, 03:52 PM   #5
Robbo,
Whats the wall built with? Blocks, bricks, concrete?
stuart45 is offline   Reply With Quote
Old 03-05-2010, 03:58 PM   #6
Xtreme DIY'r
It's not the extra weight I'm thinking of
Here someone renting an Apt is not allowed to make such renovations
Old 03-05-2010, 05:43 PM   #7
if he's in London or some of the other larger cities over there, like New York, you can buy an apartment...
Old 03-05-2010, 05:53 PM   #8
You can buy an apartment anywhere in the UK, even the smaller towns.
Old 03-05-2010, 06:25 PM   #9
Thank you Stuart, I didn't know that.
Old 03-05-2010, 06:27 PM   #10
Is it difficult to buy an appartment in the USA?
Old 03-05-2010, 07:45 PM   #11
No it's just uncommon. Mostly in NYC. Though we do have apartments for Sale everywhere here disguised as a "condo"...
The Following User Says Thank You to lemon714 For This Useful Post:
stuart45 (03-06-2010)
building a wall against an exterior wall Mike L General Discussion 2 08-20-2009 03:50 PM
Beam Building - Structual Advice projects @ home Building & Construction 2 05-03-2009 09:33 AM
Another "Need some advice on wall removal or support" thread onemo Building & Construction 11 04-14-2009 07:47 AM
Building a soffit around a drainage pipe along the wall ssudha17 Building & Construction 12 10-04-2008 04:18 PM
Question about building a wall garrettb Building & Construction 4 08-28-2008 05:38 PM
