Old 08-27-2010, 09:14 PM   #1
Advice about framing for a shower stall
We have demolished most of the original bathroom and are a little confused about how to continue. We had a 60" shower pan, but have reduced the new one to a 48" pan. As a consequence, we have to reframe new front and back walls for the shower stall. The previous ceiling for the shower is still there. The problem lies in the framing for the shower stall walls. The existing upper plates on the front and back walls of the shower are not securely attached to any joists in the ceiling (ie. joists that exist for the upstairs floor), but are merely attached by nails into an existing stud. Because of that, the other end of the plate is merely hanging in the air, now that the wall below it has been removed. So, it was the studs below that supported the upper plate.
Our question is: How do we put in a new upper plate when there is no joist handy to which to attach the 2x4?
Tooncie is offline   Reply With Quote
Old 08-27-2010, 09:54 PM   #2
jlhaslip's Avatar
got pictures?
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Solar Tube in Shower Stall? cbzdel General Discussion 3 05-31-2010 09:21 PM
shower stall with hole (cold air coming in) mcvane Plumbing 1 02-08-2009 11:41 PM
Custom Shower Project - need advice CK4500 Project Showcase 24 01-28-2009 12:59 AM
Shower Half Wall Framing Colbymom Building & Construction 7 08-01-2008 11:49 AM
caulking a shower stall Freelancer Plumbing 7 04-08-2006 10:37 PM
