Adjusting LVL Beam To Pitch Of Roof - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-03-2010, 10:03 PM   #1
Adjusting LVL beam to pitch of roof
We are currently renovating the main floor of our bungalow style house and we have had a engineer by to approve all of our renos, however we neglected one small detail.
In order to open the space up, we are installing a 11 7/8" 2 ply lvl @ 24'-0". We are also going to keep the ceiling joists exposed, lay t&g on top and cover the lvl with drywall.
In order to keep the ceiling height at a maximum, we are looking to hang the ceiling joists in the middle of the lvl. My problem is this: we have a gable roof with a hip roof on one end. The hip roof end is where the lvl beam is ending at. There is not enough clearance for the beam due to the pitch of the roof. Is it possible to cut the top corner end of the lvl on an angle in order to fit with the pitch of the roof? We were thinking 4" would give us enough to get the beam high enough to accept the ceiling joists in the middle of it and have the least amount of lvl beam reveal in our living space. I have attached a diagram to further outline what we are looking to do.
tobicol7 is offline   Reply With Quote
Old 06-05-2010, 01:22 AM   #2
iLevel by Weyerhauser has a table of allowble end tapers. Your taper is way shy of the limits they allow. http://www.ilevel.com/literature/tj-9000.pdf
You may have a different manufacturer, but all of them have these prescriptive tables for modifying their products.
housefxr is offline   Reply With Quote
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 12:35 AM
Patio Roof Beam Span slakfu Building & Construction 4 06-03-2009 10:45 PM
Attic trusses and proper roof pitch Rob63 Carpentry 1 07-28-2008 03:38 AM
Standing seam metal or membrane for 1.4/12 pitch shed roof? regulajo Roofing/Siding 21 06-18-2007 08:58 AM
Changing Pitch over roof. tying into house rafters? EnlightMent Roofing/Siding 3 03-27-2007 12:16 AM
