Adjusting Floor Joist For HVAC - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-26-2008, 11:53 AM   #1
Adjusting Floor Joist for HVAC
Trying to convert garage into family room. I want to run ductwork from
basement to attached garage.
HVAC guy wants to put a vent under my front window. Problem is that
the end of the garage (where the vent will go), is about 4' past the
end of the basement. So if I took the ductwork out of the last
basement bay, it would be about 4', and a few garage bays, away from
the target vent location.
So I need the ductwork to come out of the basement wall, hang a left,
go "through" a joist or two, and enter another bay. Then it can run
down that bay and end in the vent.
So how should I adjust my floor framing to accomodate this duct? Is it
possible to end my joist 6" before the wall, and "box it out". Will
this have negative impacts on the strength of the floor?
Thanks,
Chris
wrldruler is offline   Reply With Quote
Old 08-26-2008, 12:48 PM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
what size is the duct that he is going to run. could he use a 4"x duct. and then run it under the floor joist's. how much room do you have under floor framing?. BOB Could you post a picture???
Old 08-26-2008, 01:00 PM   #3
Registered User
Termite's Avatar
In most cases (although not all) you can header off a joist to the two adjacent joists to create a space for HVAC to penetrate.
Adjusting for Elbows in Gas Line Clutchcargo Plumbing 3 10-01-2007 01:05 PM
adjusting miter saw p8ntblr Tools 3 10-16-2006 09:16 AM
Adjusting My Garage Door Opener's UPWARD Travel cbenard Electrical 11 12-04-2005 12:24 PM
