Adjustable Structural Tension Rods - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-31-2010, 01:37 AM   #1
Rewards Points: 290
adjustable structural tension rods
I have sometimes seen these on bridges or other structures. They are composed of two threaded rods joined by a special turnbuckle with right and left handed threads to adjust the tension. Sometimes cable is used instead of rod. Smaller versions may be used to prevent sag on a wide gate or door.
I am trying to find a supplier but I don't know what they are called.
tns1 is offline   Reply With Quote
Old 08-31-2010, 01:49 AM   #2
Rewards Points: 290
Found it. "Tie rods"
Old 08-31-2010, 08:59 AM   #3
Rewards Points: 6,652
The pieces you are talking about that turn, are called what else, Turn Buckles.
Brick veneer or Structural Brick? nimblemotors Building & Construction 19 02-22-2013 09:11 PM
Help - hanging curtain rods in drywall ontheDB Drywall & Plaster 8 10-10-2009 10:54 AM
Ways to support adjustable shelves 99miles Carpentry 5 09-01-2009 06:14 PM
Structural integrity question Red Squirrel Building & Construction 8 07-28-2009 11:02 PM
Concrete steps and stucco cracked-Is this structural problem? yummy mummy Building & Construction 17 04-14-2008 10:24 AM
