Adjoining Concrete Walkway To Another Structure - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-24-2010, 01:19 PM   #1
Rewards Points: 1,062
Question
adjoining concrete walkway to another structure
my concrete walkway will go between my driveway slab and basement stairs, both are concrete, and will be adjoined to both.
i have seen some instruction saying that a walkway ought to be spaced from any adjoining structure by a 3/4" board or something.
conversely to that, i was actually planning to anchor the walkway to the top of the stairs by 4 pieces of 1 ft rebar, to prevent heave. is that a bad idea and should i space it away instead.
or instead of spacing, would it be better to adjoin directly but make an expansion joint using an edger ?
Old 08-24-2010, 11:34 PM   #2
Rewards Points: 1,092
I am no expert, but I would never attach a walkway to a house/garage unless both had the same footers/foundation wall, etc. If the walkway is floating on grade, let it float, but put it on good, compacted gravel that is well drained to minimize movement. My 2 cents. j
Walkway near big trees--how to deal with roots! jetstover Landscaping & Lawn Care 16 07-26-2011 06:21 PM
Damp Concrete Garage Floor Tom S. Building & Construction 15 03-27-2010 08:23 AM
Filling sunken living room w/ concrete Q's phil. Building & Construction 5 07-10-2009 12:03 PM
Garage concrete and driveway asphalt repairs creamaster Building & Construction 4 07-12-2008 10:51 PM
Laid Down Concrete Incorrectly overzealous Building & Construction 6 06-03-2008 06:44 PM
