adjoining concrete walkway to another structure
2K views 1 reply 2 participants last post by  jklingel
my concrete walkway will go between my driveway slab and basement stairs, both are concrete, and will be adjoined to both.
i have seen some instruction saying that a walkway ought to be spaced from any adjoining structure by a 3/4" board or something.
conversely to that, i was actually planning to anchor the walkway to the top of the stairs by 4 pieces of 1 ft rebar, to prevent heave. is that a bad idea and should i space it away instead.
or instead of spacing, would it be better to adjoin directly but make an expansion joint using an edger ?
I am no expert, but I would never attach a walkway to a house/garage unless both had the same footers/foundation wall, etc. If the walkway is floating on grade, let it float, but put it on good, compacted gravel that is well drained to minimize movement. My 2 cents. j
