Adhesive For R MATT Foam Board - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-23-2010, 05:51 PM   #1
Adhesive for R MATT foam board
I'm installing 1/2" foam R MATT rigid foam over my T1-11. The guy at Home-Depot said I could just use adhesive instead of nails. Is there any advantage using nails over adhesive?? There will be less holes in the foam using the adhesive and it should be quicker also.
captainrichhill is offline   Reply With Quote
Old 05-23-2010, 05:52 PM   #2
What's going on after the foam ?
Old 05-24-2010, 05:40 AM   #3
Hardi plank. I plan to tape all the seams on the foam.
House wrap over insulating foam board or under?? getn2old Building & Construction 7 07-28-2010 10:53 PM
fiberglass over rigid foam board in cantilever? KatieAK Building & Construction 3 11-17-2009 07:48 PM
Connecting Ledger Board to Vertical Stud Alzipski Building & Construction 3 11-04-2009 02:53 PM
Leveling Basement Floor Rigid Foam mdenis Building & Construction 6 09-07-2009 04:55 PM
Attaching foam exterior concrete wall techinstructor Building & Construction 7 04-07-2009 01:55 PM
