Adhesive For Blue Styrofoam - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-16-2011, 07:51 AM   #1
Rewards Points: 18
Adhesive for blue styrofoam
Hi,
Does anyone know what adhesive[s] will stick to a 1" sheet of blue styrofoam without dissolving into it?
I want to fasten it to the bottom half of a corroded metal freezer door that is icing up on the outside due to cold air leakage.
Thank you,
Mike
389poncho is offline   Reply With Quote
Old 05-16-2011, 08:44 AM   #2
SteelToes's Avatar
Rewards Points: 150
Well, if you are talking about extruded blue foam or polystyrene Pl300 would be the product.
Not recommended to be used on polyethylene (PE), polypropylene (PP), polytetrafluoroethylene (PTFE) and acrylic
SteelToes is offline   Reply With Quote
The Following User Says Thank You to SteelToes For This Useful Post:
389poncho (05-16-2011)
What kind of adhesive to use on Styrofoam insulation? tripower Building & Construction 17 08-13-2013 06:21 PM
Basement Flooring Question - Cutback Adhesive Atskodinski Flooring 5 12-11-2010 01:48 PM
floating laminate over old adhesive jbitt Flooring 3 09-27-2010 04:58 PM
Purchase Planipatch to cover the old adhesive ? jmpkiwi Flooring 1 02-11-2010 07:09 PM
What type of adhesive should I use to glue down accoustical cork to a concrete floo Fixitgeorge Flooring 2 03-20-2009 07:54 AM
