Which Adhesive - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-26-2011, 10:35 AM   #1
Newly Retired
tuchodi's Avatar
Which Adhesive
I need to glue some of the Dow's 2" thick Blue polystyrene sheets together. Can anyone advise which Adhesive would be the best. Thanks in advance
tuchodi is offline   Reply With Quote
Old 02-26-2011, 11:23 AM   #2
Rewards Points: 1,552
Check out:
http://msdssearch.dow.com/PublishedL...romPage=GetDoc
In it, it says:
STYROFOAM™ Brand Square Edge
Insulation boards are easy to handle,
cut using a utility knife or serrated
blade, and install. The square edge
boards are designed to ensure
energy efficiency and minimize
on-site cutting and waste. Use a
polystyrene-compatible adhesive
to
hold the boards in place during
backfilling. Apply caulk or mastic to
the top of the board to prevent
water infiltration behind the
insulation. To complete the installation,
parge the above-grade portions of
Insulation to protect from solar
radiation.
bob22 is offline   Reply With Quote
Old 02-26-2011, 11:34 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 590
Ayuh,.... PL makes a glue specfically for that,...
PL300 I think it is....
Should be easy to find at a bigbox store...
Bondo is online now   Reply With Quote
Old 02-26-2011, 11:34 AM   #4
Newly Retired
tuchodi's Avatar
That was my question which adhesive has anyone used that works well. I know it has to be compatible but as always some seem to work better than others so I was hooping someone who has glued this product together had found an adhesive that works best.
Old 02-26-2011, 11:56 AM   #5
Newly Retired
tuchodi's Avatar
Thanks I will check them out
Old 02-26-2011, 05:52 PM   #6
Bondo's Avatar
Rewards Points: 590
Btw,.. I've used it, 'n it worked as advertised...
The Following User Says Thank You to Bondo For This Useful Post:
tuchodi (02-26-2011)
Old 02-27-2011, 01:39 AM   #7
Rewards Points: 410
Yup PL300 or PL premium
I like the PL premium better but it is tough to crank through the caulk gun
( make sure the glue is warm first, it helps a lot on the premium ).
High Gear is offline   Reply With Quote
The Following User Says Thank You to High Gear For This Useful Post:
tuchodi (02-27-2011)
Basement Flooring Question - Cutback Adhesive Atskodinski Flooring 5 12-11-2010 02:48 PM
floating laminate over old adhesive jbitt Flooring 3 09-27-2010 05:58 PM
Granite & Adhesive question cody21 Kitchen & Bath Remodeling 3 07-22-2009 06:11 PM
What type of adhesive should I use to glue down accoustical cork to a concrete floo Fixitgeorge Flooring 2 03-20-2009 08:54 AM
Removing Vinyl Tile Adhesive from Linoleum The Raven Flooring 3 07-22-2008 09:38 PM
