-   -   Which Adhesive (http://www.diychatroom.com/f19/adhesive-96588/)
tuchodi 02-26-2011 09:35 AM
Which Adhesive
I need to glue some of the Dow's 2" thick Blue polystyrene sheets together. Can anyone advise which Adhesive would be the best. Thanks in advance
bob22 02-26-2011 10:23 AM
Check out:
http://msdssearch.dow.com/PublishedL...romPage=GetDoc
In it, it says:
STYROFOAM™ Brand Square Edge
Insulation boards are easy to handle,
cut using a utility knife or serrated
blade, and install. The square edge
boards are designed to ensure
energy efficiency and minimize
on-site cutting and waste. Use a
polystyrene-compatible adhesive
to
hold the boards in place during
backfilling. Apply caulk or mastic to
the top of the board to prevent
water infiltration behind the
insulation. To complete the installation,
parge the above-grade portions of
Insulation to protect from solar
radiation.
Bondo 02-26-2011 10:34 AM
Ayuh,.... PL makes a glue specfically for that,...
PL300 I think it is....
Should be easy to find at a bigbox store...
tuchodi 02-26-2011 10:34 AM
That was my question which adhesive has anyone used that works well. I know it has to be compatible but as always some seem to work better than others so I was hooping someone who has glued this product together had found an adhesive that works best.
tuchodi 02-26-2011 10:56 AM
Thanks I will check them out
Bondo 02-26-2011 04:52 PM
Btw,.. I've used it, 'n it worked as advertised...:thumbup:
High Gear 02-27-2011 12:39 AM
Yup PL300 or PL premium
I like the PL premium better but it is tough to crank through the caulk gun
( make sure the glue is warm first, it helps a lot on the premium ).
