Are Additional Supports Needed In 26' Room? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-17-2010, 09:06 PM   #1
GBunny
Rewards Points: 71
Are additional supports needed in 26' room?
One of the rooms in my basement is 26' x 13'. Other than the outside walls, there are no supports in this room. On the floor above (it's a bungalow), that same size space is divided into two bedrooms with the closet for the master bedroom located in the middle.
Originally there were floor to ceiling sliding doors in the master bedroom closet but I would like to have a bulk head installed and change to 80"H doors. It will have two 48" openings with either bifolds or regular doors, i.e. 4 doors in total. My question is whether any additional support is required in the basement under this wall/closet?
GBunny is offline   Reply With Quote
Old 04-17-2010, 10:28 PM   #2
As long as the floor joists were properly sized no additional support is needed
Ceramic or Porcelain for Front Room/Living room (advice needed) irishgem@ymail. Flooring 4 07-08-2009 01:46 PM
Japanese tea room itakitez General DIY Discussions 5 06-30-2009 02:23 AM
Should I put 2x6 or 2x10 above garage if I plan to finish the room in the future? rockne Building & Construction 35 06-08-2009 09:33 PM
A room in a room? artosie General DIY Discussions 2 03-10-2009 12:43 PM
Moving Header Supports Star Building & Construction 3 09-25-2005 12:50 AM
