Addition To A Veneer Brick House - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-17-2008, 01:40 PM   #1
Addition to a veneer brick house
What's the best way to tie an addition onto a house with brick veneer without takeing the brick off? I would think that I will need to anchor through the brick to the stud wall so all the support is not on any of the brick. Thanks for any info.
DUNN-IT is offline   Reply With Quote
Old 03-18-2008, 10:18 PM   #2
remodeling pro
The "best" and correct way is to remove the brick within the construction area, so all of the framing members can be connected properly. This will also allow a mason to weave the brick joints back together for a proper connection, as oppossed to a straight line cold mortar joint, which will always crack .
Drilling through the brick and trying to anchor something to the studs with a 9 ' lag screw has no structural integrity.
troubleseeker is offline   Reply With Quote
Old 03-18-2008, 11:15 PM   #3
Rewards Points: 1,220
It depends upon the design. Sometimes you will want the connection to be a soft joint and others you will want to tooth it in with the existing brick. Generally, a soft joint at a natural turn of plane is best while an in-plane joint should be racked back and toothed.
Tscarborough is online now   Reply With Quote
Old 03-19-2008, 05:36 AM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
In the circumstances of attaching an addition, there is no a way in the world, that you can leave the brick veneer on the main structure (at the addition location).
It HAS TO be removed, in order to properly, and securely, attach an addtitional structure to the home.
- Build Well -
Old 03-19-2008, 09:14 AM   #5
Thanks for the advice.
Complete AC installation in Old Capitol Hill Row House jacko10 HVAC 0 09-18-2007 06:42 PM
Brick Veneer on steel angle iron sandyman720 Building & Construction 3 07-09-2007 09:21 PM
Brick a house 3DPiper Building & Construction 2 03-28-2007 04:14 PM
Brick and block house footer question. ourzoo Building & Construction 2 07-01-2006 03:57 PM
