-   -   Addition foundation forming cheaply... (http://www.diychatroom.com/f19/addition-foundation-forming-cheaply-2569/)
MLO 05-23-2006 12:48 PM
I will be forming near 60ft.(120ft. both sides) of foundation off existing structure. It will have 8in.tall footings and 20" tall walls. Current foundation on home is 9" thick as it has a roman bricked exterior (will match). Current wall frame is 2x4's and new walls will be 2x6's. Does this mean I add 2 inches to the thickness of the new foundation wall for a brick ledge (9"+2"=11" thick)?
What is the most cost affective way of forming this? Time I have, money I need to be prudent with. Rental forms seem to be a hassle for this kind of project and not cheap.
TIA!
MLO 05-23-2006 04:27 PM
Considering the actual size of the foundation is fairly small, I am interested in a possible monolithic style forming and pour. Can anyone lead me to a place on the net where I can see such a form set-up?
Teetorbilt 05-23-2006 10:22 PM
You don't state where you are. I would suggest consulting with your local bld. dept. for the requirements on your slab.
MLO 05-24-2006 03:51 AM
No slab, just a footing and foundation wall. Climate is mild and soil is very stable.
MLO 05-25-2006 07:43 PM
After some research, it appears it will be cheaper to just rent 1 1/8" form panels.
The existing foundation is 9" wide for the exterior brick wall to be built on. I was going to continue this "extra-wide" foundation wall, but have been told to just use the 6" wall called for on the prints and let the masons use "blocks" to build up the footer/wall for the new brick wall to rest on. Seems the cost of a little more concrete in this case would certainly save some labor and be stronger down the road...any opinions?
