Addition To Existing Walk Out - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-17-2008, 12:27 AM   #1
Quasi Painter
Addition to existing walk out
Ok, I've got this existing house, circa 1950's...was moved from original site to new location on new concrete walk-out foundation...On the side of the addition the foundation at tie in protrudes about 2 feet above grade and grade drops about 4 feet over the expanse of the addition...walk-out not an issue.
I'm not wanting to pour a new basement just a foundation with crawl space...Should I have an escavator build up the existing grade then dig footings, or skip the build up and opt to pour the deeper wall?
alittleboutalot is offline   Reply With Quote
Old 12-17-2008, 03:26 AM   #2
Rewards Points: 5,336
The footings need to be below the frostline. Pour the footings and foundation first. You can backfill later if you like that look.
Ron
!!HELP!! Rain leaking between existing home and new addition NJGirl357 Roofing/Siding 4 09-10-2008 05:06 PM
to add an addition or not..... elmorem@gmail.com Building & Construction 2 02-17-2008 10:43 PM
Question: second story addition to existing room elmorem@gmail.com Building & Construction 3 02-17-2008 09:38 PM
Flat roof addition - Joists connected to structure via legerboard?? Rhino17 Building & Construction 2 09-01-2007 06:56 AM
Addition around existing brick chimney Adenmoor Building & Construction 2 11-20-2004 10:37 PM
