-   -   Adding a window (http://www.diychatroom.com/f19/adding-window-158027/)
Jim1962 09-26-2012 06:55 AM
Adding a window
My wife and I want to add windows to out two upstairs bathrooms. I plan on having the windows installed by the company that is doing our siding this fall. But I want to save some money by doing the rough opening myself so all they need to do is put the window in (I have no desire to do that part my self 20 feet off the ground).
My question is if I build a rough opening with 2x4's as a frame and set it into place, does it sit in line with the existing studs or is it off set a bit either to the inside or the outside, and if so by how much? Thanks.
allthumbsdiy 09-26-2012 07:57 AM
Depending on the size of your window, you probably will need to remove at least one stud.
Centering between studs will depend on exactly how you want the window to be positioned in a given wall.
PS. For your rough opening, you will need to go on a ladder from the outside, remove siding, underlayment. You can probably cut from the inside but you will need to install a temporary cover from the outside.
Good luck
Joe Carola 09-26-2012 08:01 AM
Is it a load bearing wall?
user1007 09-26-2012 08:42 AM
You are going to need a header to replace the structure you remove. Just to start. If it is a bearing wall and you are putting a hole in it, you are making a major structural change and will probably need at a least a quick drawing, sign-off, permit and inspection.
I know you want to save some money but my instinctive feathers are ruffled by your approach. Are you sure it is worth doing this yourself?
joecaption 09-26-2012 08:46 AM
On a second story I'd be setting up two ladders, ladder stand offs, and a walk board to work off of. Hard to remove siding with just one ladder.
What type siding do you have.
hand drive 09-26-2012 09:33 AM
you will want exact dimensions from the window manufacturer and even then they are sometimes not right, windows and doors are one of the worst things to go wrong in construction, especially add in later windows and doors. You will also need to know how to header off the opening and will need to pull drywall from the wall - floor to ceiling - to get full length studs and jacks added into the wall around the openings. Obviously you will want to fit the opening into the wall without moving as much structure as possible- meaning, cutting the header into the wall from one side etc...
oodssoo 09-26-2012 03:10 PM
One thing to consider here:
You could technically do the opening from the inside without risking your life over a 20' drop. I imagine you could simply just cut out the drywall where the windows will go, and take the project from there...
mae-ling 09-26-2012 03:44 PM
Could do the rough opening from the inside leaving the sheeting and siding for now, then when they are residing they could cut out the plywood in the opening, nail the edges, and install the housewrap, flashings and wdw.
Not an impossible job at all.
But you are changing structure, and have to take things into account.
Can you show pictures of inside and outside of house where wdw's will be going? Also size of windows?
What siding is on the house now?
Is this window above a toilet, tub, vanity or some other thing?
mae-ling 09-26-2012 03:50 PM
Here is an idea of the framing you need in the wall. use 2x4 or 2x6 or whatever your existing wall has for studs.
http://t0.gstatic.com/images?q=tbn:A...zTiZLYVTD14lHH
http://www.gotchashuttered.com/wp-co...8/diagram1.gif
kwikfishron 09-26-2012 07:15 PM
199 Attachment(s)
If you have the inside of the bathroom wall already opened up for other reasons then I can see this being a worthwhile project , otherwise I'd leave it to the siding guys.
You shouldn't be removing siding and opening up the wall unless it can be all put back together (leak free) the same day.
mae-ling 09-26-2012 07:17 PM
No need to open wall to frame from the inside, leave the sheeting and siding intact until siding guys come, the rest can be done from the inside.
kwikfishron 09-26-2012 07:36 PM
199 Attachment(s)
What??? Not if it's a bearing wall that needs a solid header, the new hole in an existing wall can be done from the outside without unnecessarily disturbing anything on the inside.
In other words, no drywall work necessary if the window all trims in wood.
mae-ling 09-26-2012 07:42 PM
That is true, For some reason I thought they were doing work in the bath rooms as well, perhaps you are right and they are just adding the windows. May be easiest and best to do it from the outside then.
