Adding A Wall, What Type Of Wood? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-22-2008, 12:17 PM   #1
Rewards Points: 45
Adding a wall, what type of wood?
I'm installing (or extending rather) a wall in my house which has a concrete slab. I noticed that the 2x4 bottom plate that touches the concrete on the existing wall seems to be the color of pressure treated lumber. Should I use pressure treated lumber for the bottom plate of my new wall?
Matt
Lafayette, LA
GeauxCajuns82 is offline   Reply With Quote
Old 12-22-2008, 12:36 PM   #2
DIYer
Yes.
Gigs is offline   Reply With Quote
Old 12-22-2008, 12:44 PM   #3
Registered User
Termite's Avatar
Yes you should. You must also use hot-dipped galvanized nails for all nails that go into that treated material.
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Gluing greenboard to cement wall... tips? AdamB5000 Remodeling 5 03-31-2008 11:11 AM
How to butt wood stud wall to steel stud wall? Yorkergizer Building & Construction 3 12-01-2007 01:28 AM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
