Adding Storage - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-14-2010, 01:48 AM   #1
bnj
Adding storage
We don't have a lot of room for storage, but we have a high garage area. I want to build a floor area and hang it from my roof rafters. However I don't know how much weight they will hold. Does anyone have any suggestions?
Thank you all for your help.
bnj is offline   Reply With Quote
Old 09-14-2010, 07:06 AM   #2
What size is the garage ?
Old 09-14-2010, 10:00 AM   #3
bnj
I am only going to do about an 8'X8' storage section and suspend beams from the rafters to hold some storage. I am estimating high and saying no more than 600 lbs. But I am not good with weight. I was thinking of taking 2x4 and building a base then putting plywood on top of that. When that was finished, I was going to suspend it from the rafters and have some storage. I am just not a carpenter and didn't know if that would damage my rafters. If I have to put a support beam up, it will defeat the purpose of using the upper garage space. Sorry I wasn't more clear, any suggestions or advice would be extremely helpful.
Thank you
Old 09-14-2010, 11:45 AM   #4
What size are the rafters ?
2x6, 2x8....2x10.....trusses ? Pic would help
Will this be built against one wall/side of the garage ?
One car...2 car garage ?
Old 09-14-2010, 12:08 PM   #5
steveel's Avatar
If you have a winter, think about the weight of the snow, too. An hour of structural engineer consultation time might be advised.
steveel is offline   Reply With Quote
Old 09-14-2010, 12:22 PM   #6
Rewards Points: 156
A previous owner did the same thing you are talking about doing and it sagged the garage roof down to where I was getting worried it would collapse come 1 more winter. It was attached on 2 walls and hung near the center up to the rafters. The 2 walls of my garage started to seperate as the roof sagged and the rafter nails started pulling away from the ridge beam. After tearing down this makeshift loft this is how I had to suppport my roof (rafter ties,metal fasteners on rafters and ridge beam,cable tie to both walls)... I would do as suggested and consult with an engineer or you may have this same thing happen
creamaster is offline   Reply With Quote
Adding Microlam to garage, to support 2 doors and storage??? Shannon Building & Construction 8 10-19-2011 11:58 PM
Adding insulation and storage to Cape Cod Side Attic turin39789 General DIY Discussions 5 11-08-2010 10:50 AM
Adding storage to window seat apruden Carpentry 2 11-06-2009 04:54 PM
Newbie looking for any help and info that I can get on adding this bathroom.... iwtmkc Kitchen & Bath Remodeling 3 12-12-2008 02:10 PM
Adding crawl space access and storage farmerde Roofing/Siding 2 11-10-2008 10:26 PM
