Old 02-01-2011, 08:56 PM   #1
adding a step
The threshold over hangs the foundation and is now is starting to break off. I was thinking of adding a cement step to support the threshold. Should I drill holes and add rebar to hold the step in place? What would be the best solution to the problem?
Barnell is offline   Reply With Quote
Old 02-01-2011, 11:49 PM   #2
Residential Designer
AndyGump's Avatar
Send a message via Skype™ to AndyGump
adding a step
Sorry, I don't understand the what the problem is and I don't know what that is in the picture.
Is that in the crawl space?
Andy.
AndyGump is offline   Reply With Quote
Old 02-02-2011, 12:12 AM   #3
adding a step
build a step out of 2x12's much much cheaper
proremodel is offline   Reply With Quote
Old 02-02-2011, 01:11 AM   #4
Moderator
Termite's Avatar
adding a step
Looks to me like someone used a 2x6 wall thickness door in a 2x4 wall? I'm assuming we're looking at the underside of a door threshold, and the side of the door jamb. Wierd.
Yes, you can pour a concrete step there pretty easily. If you want to tie it to the wall you could epoxy a couple pieces of all-thread or rebar into the wall and pour the concrete in a form with some simple reinforcement. The step can't exceed 7-3/4" in height, and the two rises (or three) must be consistent within 3/8" of each other to meet code. The step must project at least 10" horizontally off the nose of that threshold as well.
I would personally build it from treated lumber, but I'm more of a carpenter than a flatworker!
Old 02-02-2011, 12:08 PM   #5
adding a step
Andy.
The photo is the bottom of the door over hanging the wall. I want to add a step to support the bottom part so it doesn’t break off.
How should I attach the treated wood? Just use an epoxy or bolt into place? I have the same issue on an outside door can I attach the wood the same way or do I need some type of weather barrier?
Old 02-02-2011, 06:31 PM   #6
Moderator
Termite's Avatar
adding a step
You can attach to the foundation with wedge anchors. You will need a hammer drill to drill any hole into the concrete, regardless of the anchor you choose. Epoxy alone won't do the job.
Unfinished step around wood laminate floors markq Flooring 7 07-17-2009 08:19 PM
Removing a cement step on outside of house Vikeologist Building & Construction 5 06-18-2009 01:33 PM
tiling outdoor step kristinmcdonald Tiling, ceramics, marble 6 06-09-2009 12:02 AM
Step footing has gaps joshoc Building & Construction 4 05-06-2009 05:11 PM
How Should I Frame this Single 10' Wide Step? Chris' Place Remodeling 4 04-02-2008 10:31 PM
