Adding Soffits To A Bedroom By Going Up - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-14-2012, 03:16 AM   #1
Adding soffits to a bedroom by going up
We have some friends who modified their bedrooms by adding soffits (at least this is what they called them, correct me if I'm wrong, they look like recesses). However instead of dropping the ceiling down a few inches, they went up. I haven't seen much information about this, but the end effect was stunning and we want to consider doing the same, but I kind of wanted to get a feel for how safe this is on the structure of the house.
Here's basically how they described the process:
1.) In the attic, add 2x6's on top of the existing ceiling joists (attached via liquid nails and steel plates with bolts on either side of the soon-to-be-raised area).
2.) Add cross-bracers to the new 2x6's to prevent twisting and to provide extra support for ceiling fan.
3.) Cut away the drywall, exposing the joists
4.) Cut out the section of the joists between the attachments in step 1
At this point you have roughly a 6 inch recess. Drywall, molding, lights, electrical, etc, and you're done.
Now, this is my first house, so you'll understand if I'm a little hesitant about messing around with joists and such. Is this generally a sound plan? Or is there some massive weakening of the overall structure that I'm missing?
Shaftway is offline   Reply With Quote
Old 05-14-2012, 05:46 AM   #2
DIY staff
Rewards Points: 7,174
What you are talking about is a 'trayed' ceiling---
Before you go any further in your planning--post a picture from up in the attic--
If you have roof trusses you are out of luck,they can not be modified ---
More info needed---those ceiling joists do more than hold up the ceiling--they also keep the outside walls in place. done wrong the structure will be compromised.
Ravenworks (05-15-2012)
Old 05-14-2012, 05:49 AM   #3
Stay-at-home GC
Tray Ceiling.
Neat idea. Can't speak to the structural aspect but as a Carpenter (In-training) I don't see why it couldn't be done right.
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Old 05-14-2012, 05:59 AM   #4
Good to know. Unfortunately I actually can't yet. It's new construction and currently is a concrete slab. We're trying to plan out various things we want to add on and this is one that seems like it's more labor than materials.
The houses a block away are being framed, so I'll see if I can get a shot of them. Worst case, we're scheduled to do an inspection walkthrough in a couple months, before any sheetrock gets put up, so we can check it out then.
Other than the truss situation, is there some other piece of info I need?
Thanks, appreciate the answers.
Old 05-14-2012, 06:42 AM   #5
DIY staff
Couldn't you talk to the builder? Ask for a set of blue prints for the house---It will be cheaper to modify the plans now,rather than pull down new work to make the modifications after the house is complete.
Even if the houses use a trussed roof,the trusses could be made for your trayed ceiling---
Old 05-14-2012, 07:10 AM   #6
Framing Contractor
That's not the way it works. Any thoughts of changes in the framing HAS to be done NOW!!! You have a set of plans, go to the job today ... tomorrow....or simply call your builder and tell him what you are thinking. It has to be discussed now because it changes the framing structurally. You don't wait til the framing ...electrical....plumbing...hvac....insulation...e tc... is done and then rip things out that are in the way.
What you are thinking of doing is done every day. Very easy to have it designed and done during the framing process. Trust me, this is the time to do it and the cheapest time to do it.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 05-14-2012, 06:41 PM   #7
Yeah, we started down that route. It's a builder who builds houses in a quick row. Most change requests are shot down, and the few that are approved are ludicrously expensive. For example, getting french doors instead of sliding glass runs north of five grand, provided you also supply the doors and they're the exact same size as the sliding glass.
I imagine this would be well into the 5 digit realm.
Old 05-14-2012, 07:17 PM   #8
Framing Contractor
Rewards Points: 120
Sounds like this is a tract home. I would bet the farm that these are trussed.
sixeightten is offline   Reply With Quote
Old 05-14-2012, 10:03 PM   #9
Just a DIY guy
I'll bet at least a nickel you are right. Trusses are fast, easy, and best of all, cheap.
And if the builder paid for a bunch of sets for each model, the chances of getting a custom set for one home is pretty slim.
But you have nothing to lose by asking ... NOW. You never know, he might let you pay the difference to the truss company.
M3 Pete is offline   Reply With Quote
Old 05-15-2012, 03:13 AM   #10
Oh, the question is in. Expected turnaround time is over a month, so now it's a waiting game.
In the end it probably won't be worth it and we'll just install boxes. The ceilings are 9 foot to start off with, so we won't notice losing a couple inches, but doorways are 8 foot, so I'll have to keep an eye on how close the molding gets to doorways.
Cold bedroom chronojosh Building & Construction 9 12-23-2011 02:43 PM
cold bedroom redcedar HVAC 1 01-13-2011 08:51 AM
Convert bedroom into a bathroom? ChrisDIY Plumbing 10 04-28-2010 10:04 PM
Master bedroom placement near dining/living room EdieKay Remodeling 0 04-11-2010 06:48 PM
Adding Electric outlets to bedroom with plaster walls jimmyfloyd Electrical 13 11-07-2008 03:20 PM
