Adding Slab To Slab - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-31-2011, 08:08 AM   #1
Adding slab to slab
I am thinking of buying a 24' x 34' house built on a slab foundation and want to add a 17' x 34' ell that would also be on a slab foundation. Can the slabs be joined so there will be no shifting over time?
Karenew is offline   Reply With Quote
Old 03-31-2011, 10:17 AM   #2
General Contractor
Yes, but...
Karen,
It is possible to install a new slab next to an old slab so that there will be no appreciable shifting in the next 100 years or so.
You may well have a hard time avoiding an eventual crack between the two, and there are any number of problems/concerns that might have to be managed depending on your specifics.
Essentially, it can be done.
Have fun,
Rory
Rory
RDG Read Development LLC
Portland, OR
Rory Read is offline   Reply With Quote
Old 03-31-2011, 10:24 PM   #3
Rewards Points: 1,092
I'd suggest that it is structural engineer, or very experienced concrete installer, time. You will probably be tying slabs, foundation walls and footers together, using rebar, a concrete drill, and epoxy. This, as mentioned above, is not a huge deal, but it needs to be right.
Extending Patio Slab and adding a cover Jeoroc24 Building & Construction 5 04-12-2011 11:16 AM
Adding fittings to mid run of a main under slab...???? antalamo Plumbing 0 03-22-2011 12:14 AM
adding new radiators to a slab home renofixit99 HVAC 2 01-02-2011 06:13 AM
Adding a footing to an existing slab on grade jascox Building & Construction 4 07-05-2010 02:20 PM
Adding foundation under a slab. bob grube Building & Construction 9 02-02-2010 11:08 AM
