Adding Shed Addition To Gable Roof - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-31-2009, 08:55 PM   #1
Adding shed addition to gable roof
Hi all,
I have a garage with a 4.5/12 pitch roof with 2x4 truss construction. I would like to extend the roof (at the same pitch) to make a shed addition on the side of the garage by about 6 feet. My question is how to join the rafters for the addition to the side of the garage.
The options I can think of are:
1) Cut off the tails of the trusses (which now make the 1 foot eave), put a 2x6 parallel to wall (perpendicular to the trusses, like a ledger board for rafters (not sure what it would be called)) and nail the new rafters into the 2x6. This will allow all the rafters to be in line with the top chord of the truss.
2) Sister new rafters onto the top chord of the truss - the rafters will be offset by 1.5" relative to the trusses.
What is the proper way to do this?
Thanks,
don
desch is offline   Reply With Quote
Old 08-31-2009, 09:00 PM   #2
Framing Contractor
Originally Posted by desch View Post
Hi all,
Thanks,
don
Don,
The right way to do it is to run the new rafters along side the trusses and cut a birdsmouth on the rafters and sit it on the top plate. You outside wall at the 6' mark you know will roughly be about 27" shorter.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 08-31-2009, 09:19 PM   #3
Originally Posted by Joe Carola View Post
Don,
Joe,
Wow - thanks for your quick reply! Sounds good!
don
Addition and Roof Replacement lebeld Roofing/Siding 4 01-04-2009 06:11 PM
ventilation in new shed roof addition berta Building & Construction 4 10-21-2008 04:33 PM
Flat roof addition - Joists connected to structure via legerboard?? Rhino17 Building & Construction 2 09-01-2007 06:56 AM
Shed type roof addition on Brick home? sandyman720 Roofing/Siding 6 04-24-2007 02:35 PM
Venting a shed roof with 2/12 slope atulc Roofing/Siding 5 08-25-2006 07:28 AM
