Adding Rooms Under Cottage - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-07-2008, 06:46 PM   #16
Master General ReEngineer
Bondo's Avatar
Rewards Points: 354
Ayuh,.....
But if you don't Lift the Whole Structure,+ support it from away from the footprint,...
You're setting yourself up to Slide the Whole thing down the hill,....
When all the uphill supporting area Falls into your Dig.....
You need a fair bit of Distance between the earth supporting the structure,+ the earth you're Digging......
Especially on a Sidehill.....
Old 03-07-2008, 07:41 PM   #17
Home Renovations GC
kiwi54's Avatar
Originally Posted by billybarty View Post
Maybe I didn't explain it properly, I'm not raising it. It sits on the side of a hill with the back of the house resting on the hill. The front is about 4 feet off the ground. I want to hold up the front so I can dig out underneath to build a room for my utilities. I don't think using ties for cribbing and a good beam under the front is unsafe or too difficult to do.
billybarty.......you explained enough and came here looking for good advise....you've been given it but you're not listening. Bondo explained what we've all tried to tell you. Your house needs to be COMPLETELY supported above the ground you are about to disturb, those supports need to be set at an approved distance from the work area so that when you do disturb the ground no excess pressure is placed on the weakened ground by any part of the house or supports. Otherwise you might just as well tie a set of skis underneath it and wave it bye-bye.
You're looking for an easy and cheap way of doing this, there isn't one. There's only a right way. Again, go to a pro and have them do it right.
Quote: Tis better to stay quiet and be thought a fool than to open one's mouth and remove all doubt.
kiwi54 is offline   Reply With Quote
Old 03-10-2008, 10:01 AM   #18
There is about 10 feet of structure that will still be sitting on the slope away from the excavated dirt. Thanks for the advice
billybarty is offline   Reply With Quote
Adding a wall switch to a pull chain fixture abacuslearns Electrical 17 12-20-2011 07:02 PM
Design rules for wood floors in adjacent rooms chrish Flooring 1 09-10-2007 08:04 PM
? about 70's cape and how to open rooms angelonbreak Remodeling 3 04-25-2007 08:59 AM
92V AC in two rooms david_winters Electrical 1 12-11-2005 04:33 PM
adding a second floor chubdo Building & Construction 11 04-16-2005 01:20 AM
