Adding A Room Or Loft Above 2 Story Vaulted Family Room - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-01-2012, 02:53 PM   #1
Adding a room or loft above 2 story vaulted family room
Hello,
We are outgrowing our space and would like to add a room or loft above our vaulted 2 story family room. The dimensions are 16'-2"x16'-3". I have attached a picture of the room. Additionally you can see a 360 tour here: http://www.pulte.com/communities/ga/...-ii.aspx#tab41 click on "360 Home Tour" and then "Great Room". You can navigate the room with the cursor. Can any of you envision a way we can add some useable space in this area?
Thanks so much!
chemjacket is offline   Reply With Quote
Old 02-01-2012, 03:41 PM   #2
DIY staff
Rewards Points: 7,174
Couldn't get the link to show me a 360 picture.
Can you post a picture from the windows showing the stairs?
Old 02-01-2012, 03:57 PM   #3
Here is a picture showing the stairs
And then if it helps any, here is a picture of the back of the house.
Thanks!
Old 02-01-2012, 04:29 PM   #4
DIY staff
It can be done---but you need to have the support walls checked by an engineer or architect and any modifications designed for you.
I expanded the balcony of this house when the kids needed an office for school work---
I built the house and knew the original framing first hand--so it was easy--but you don't have that advantage---
Old 02-01-2012, 07:33 PM   #5
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
How about adding a room to the side of the house.
It would be a shame to cut into that nice vaulted space with some weird loft.
Andy.
AndyGump is offline   Reply With Quote
Old 02-02-2012, 07:52 PM   #6
It probably won't pass the board.
Based on the square footage and the angle of the ceiling, there won't be enough "usable" square footage at code minimum ceiling height to be classified as a "room."
If you are able to get a plan passed, in the end it will cost you big time in equity and will probably reduce the value of the home due to appeal. Are there any other opportunities to reclaim space?
RenoStruct is offline   Reply With Quote
Vaulted ceiling crown molding with adjacent room cmcfalls2 Carpentry 4 10-13-2011 10:38 AM
family room remodel analogmusicman Remodeling 6 08-26-2011 09:10 PM
Recessed Light Layout / Family Room ericm215 Electrical 2 07-03-2011 11:18 AM
what is better for a small room " junior loft or a full loft ?" irishguy76 Carpentry 3 05-23-2011 09:17 AM
Family Room Project ktkelly Project Showcase 0 05-16-2007 08:48 PM
