Adding A Room, Footings For All Walls, Or Just New Exterior? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-25-2006, 10:51 AM   #1
mt232's Avatar
Adding a room, footings for all walls, or just new exterior?
I'm planning to add a room, two of the walls will be new exterior walls, the other two meet the existing house. Do I need footings below all four walls, or can I tie into the two existing walls? My concern is that there is a soon-to-be filled oil tank below the room and I hope I don't have to dig footings near it.
Thanks!
mt232 is offline   Reply With Quote
Old 09-25-2006, 03:56 PM   #2
you need footings under load bearing walls and columns. it really depends how you plan to frame it, i dont see why you can get away with the 2 footings. really you have tyo draw something up and go to your local town building department.
jamesdart is offline   Reply With Quote
Old 09-25-2006, 07:55 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Yes, you will definitely need some kind of footings. That is required by code. & Yes there also will be an issue regarding that oil tank.
- Build Well -
Running coax from attic to room below, via exterior wall? curls00 Electrical 13 08-15-2007 03:18 PM
Adding a Additional Room christopher_45 Building & Construction 1 06-29-2007 05:23 AM
Adding closet to carpetted room. Sole plate on top of carpet? roysoto Building & Construction 2 09-23-2006 12:01 AM
how-to replace subfloor next to exterior walls tdonly Flooring 2 07-28-2006 01:41 AM
painting a room w/ both drywall and plaster walls J187 Painting 7 06-19-2006 06:33 PM
