-   -   Adding a room, footings for all walls, or just new exterior? (http://www.diychatroom.com/f19/adding-room-footings-all-walls-just-new-exterior-4074/)
mt232 09-25-2006 09:51 AM
I'm planning to add a room, two of the walls will be new exterior walls, the other two meet the existing house. Do I need footings below all four walls, or can I tie into the two existing walls? My concern is that there is a soon-to-be filled oil tank below the room and I hope I don't have to dig footings near it.
Thanks!
jamesdart 09-25-2006 02:56 PM
you need footings under load bearing walls and columns. it really depends how you plan to frame it, i dont see why you can get away with the 2 footings. really you have tyo draw something up and go to your local town building department.
AtlanticWBConst. 09-25-2006 06:55 PM
Yes, you will definitely need some kind of footings. That is required by code. & Yes there also will be an issue regarding that oil tank.
