Adding Roof To Existing Deck - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-05-2012, 11:12 AM   #1
adding roof to existing deck
Question about pricing. My parents have a 20Lx10w deck at a place on the beach. Not right on the water. They have gotten a quote of $35000 for the addition of a roof to this deck.. The guy will have to put some more supports on the existing deck. The house is up on stilts. We think this is a really high price for a roof! Any opinions out there!! Thanks in advance for any help!
sgh36 is offline   Reply With Quote
Old 06-05-2012, 11:26 AM   #2
GBrackins's Avatar
Rewards Points: 2,108
First, Welcome to the Forum!
I refer you to this post "How much will it cost?" Asking for price estimates here.
with that said do you have construction drawings? if not, how does the builder know what is required to be done? check with your local building department and find out the requirements for this type of project. They will probably require a building permit for this type of project and construction drawings. You do not state where you are located so I'm limited in providing specifics.
wind resistant construction is a challenge when creating a partially enclosed structure such as this, especially on a beach. Wind coming in off the open water can hit with as much as 40% more force than the same wind moving over inland areas. Wind acts not only on the deck and the roof of the structure, but the ceiling as well. It must be properly braced and connections designed to resistance lateral, shear and uplift forces from the wind. The higher off the ground the structure is the more challenges you face. It's similar to designing a sailboat such that when the wind fills the sail it will not move in the water.
I would recommend having a professional engineer prepare construction drawings for your project if you have not already. You can always save the money that an engineer would cost you, and end up with a structure that is not only unsafe, but may fail in a high wind event (storm).
Lastly check with other local builders and get quotes from them. What things cost in one part of the country is not the same in others. Pricing is not one of the valuable services this forums provides ....
Good luck with your project!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 06-05-2012, 11:35 AM   #3
Framing Contractor
Read the sticky about pricing here. It's impossible to give any answers.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 06-05-2012, 07:34 PM   #4
robertcdf's Avatar
It might be high, it might not be. We don't have the full specs, engineering, plans, materials, etc to even consider making an educated guess. Could be the guy just doesn't want the project so he is bidding high hoping you'll call someone else.
robertcdf is offline   Reply With Quote
Roof Over Deck Bob Haskett Building & Construction 5 02-16-2011 02:54 PM
Help with adding a roof over my deck robdec Roofing/Siding 14 11-07-2009 09:08 PM
Patio Around an Existing Deck tonyg Landscaping & Lawn Care 1 09-10-2009 06:57 PM
Extend House Roof Over Back Deck Justahome Carpentry 17 04-05-2009 03:42 PM
Extend House Roof Over Back Deck Justahome Carpentry 1 04-03-2009 07:25 PM
