Adding On To Pool Area Slab - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-07-2011, 02:54 AM   #1
Adding on to pool area slab
I'm in the process of remodeling a mid 80's home in Costa Rica and need some advice. Around the pool area were some ugly ceramic and concrete benches. I removed them and as you can see there is nothing but dirt underneath. I want to pour concrete in these areas. I have a few questions.
1. How should these new areas be sloped?
2. What type of drainage should be incorporated?
3. Should the rebar for the new slabs be tied into the concrete next to the pool or the house footer or both?
Adding on to pool area slab-dsc01254.jpg   Adding on to pool area slab-dsc01255.jpg   Adding on to pool area slab-dsc01252.jpg   Adding on to pool area slab-dsc01251.jpg
fatboyelroy is offline   Reply With Quote
Old 03-07-2011, 08:47 AM   #2
Rewards Points: 4,442
you'll need some isolation jnt material & a diamond saw to square up the existing conc,,, just pitch the new conc so rain doesn't enter the pool,,, if it were mind, i wouldn't be using any tie bars because the pool & house are structures,,, ixnay on tying into them.
Old 03-08-2011, 11:25 AM   #3
Thanks itsreallyconc for the input. How many drains would be sufficient and what size pipe? Aside from the factor its in close proximity to the pool here in Costa Rica the rain can be intense. I want to move as much water as I can quickly away from the pool and house. Also at a later date I intend to put a decorative concrete overlay over the new slab and over the old tile around the pool. Would that change the scheme of things?
Old 03-08-2011, 11:32 AM   #4
from your pics, you don 't need any drains that i can see so let the ALMIGHTY drain it for you just place your conc so there's a slope & wtr will run downhill [ trust me on this ! ]
dec conc o'lays can range in thickness from 1/16" ( troweled ) up to 5/16" ( thin stamped ) so plan your elevations accordingly.
Old 03-08-2011, 01:12 PM   #5
Rewards Points: 1,520
How should electrical bonding be done with new concrete to existing pool bonding?
bob22 is offline   Reply With Quote
Old 03-09-2011, 06:18 AM   #6
' electrical bonding ' ? ? ?
Old 03-09-2011, 10:34 AM   #7
Bonding of the rebar used in the new concrete to that of the rebar and associated metal of the pool (ladders, pump, lights,...) already bonded.
Old 03-09-2011, 01:48 PM   #8
we wouldn't use reinforcement in the new concrete since it appears to be only 4" thick HOWEVER that does raise a good point - should there be a ground ? i don't know but will ask & report back.
Adding insulation and storage to Cape Cod Side Attic turin39789 General DIY Discussions 5 11-08-2010 11:50 AM
inground pool cement deck/pad newbie pool Building & Construction 2 06-26-2010 11:02 PM
Suggestion for new sidewalk slab flyboy_ont Landscaping & Lawn Care 7 05-22-2009 12:15 PM
Sagging concrete pool deck Immolate General DIY Discussions 1 06-11-2008 10:16 PM
Post-tension slab in Dallas, TX Area kberger Building & Construction 1 10-12-2006 12:49 PM
