Adding New Stud (framing For A Door), Can Only Access One Side - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-04-2010, 06:11 PM   #1
ckk
Adding new stud (framing for a door), can only access one side
Hi All,
New to the forum. I'm moving a door a few feet over in a load bearing wall. My plan is to cut the current drywall where I want the new door to end up, so that I don't need to refinish the skip-trowel texture on that part of the wall.
I was going to slide a new king stud (and then jack stud) into the drywall so that the jack stud ends flush with the edge.
This means that I only have nailing access to one side of the king stud when nailing into the top plate and bottom plate of the wall...
Is this ok? Or do I need to take the drywall off around the king stud location so that I can nail into both sides?
Thanks in advance!
--CK
ckk is offline   Reply With Quote
Old 06-04-2010, 06:24 PM   #2
kwikfishron's Avatar
Rewards Points: 82
Are you also going to slide a new solid header in for your load bearing wall?
If you don’t mind wide trim on the inside you can pull it off.
What happens to the old hole in the wall, no drywall work there?
You didn’t say if the door is interior or exterior, if exterior I’d be looking at “nicely” removing siding, frame in the opening then cutting drywall.
kwikfishron is offline   Reply With Quote
Old 06-04-2010, 06:50 PM   #3
ckk
Thanks for the quick reply. I'm planning to re-use the same header that's already there, and slide it over. The new door frame will actually be slighly narrower than the old, so I can just cut a few inches off the header.
It's an interior wall. On the side that currently has no drywall, I will add new -- it goes into a corner, so the "new" skip trowel will be harder to notice...
Basically, If I need to toe-nail both sides, or nail into the header from the outside of the king stud, I will take off more drywall. Just don't want to interrupt the current texture if I don't need to since I suck at both taping and texture :-)
Thanks,
--CK
Garage framing rotted, back side dropped 3" zetti1102 Building & Construction 12 08-06-2009 09:18 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 04:49 PM
Metal Stud Framing in Basement toolman327 Building & Construction 2 01-01-2009 07:52 PM
Adding a room, tie in to existing framing rampeyboy Building & Construction 4 12-26-2008 04:16 PM
recessed bath tub framing amakarevic Building & Construction 1 06-03-2008 11:11 AM
