Adding Lattice To Garage - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-12-2013, 05:02 PM   #1
Rewards Points: 308
Adding Lattice to Garage
If you look closely in the picture below, you can tell that a portion of our garage has exposed painted block. Looking to cover that (and to add some architectural interest, too) with black painted lattice and then choose a vine to grow.
As you can see, I have one piece of partially-painted lattice leaning against the building now. I've got one more piece (both of which I bought at the ReStore) that will go next to that one. I am going to have a bit of a gap on either side and am looking for ideas to to frame out the lattice. Any creative ideas are welcome! Using this pool house below for inspiration. Please give me your input!
smokey847 is offline   Reply With Quote
Old 01-12-2013, 07:16 PM   #2
Rewards Points: 13,752
Not a great plan if your idea is to attach the lattis direcly to the block wall.
2, 4 X 4's, 1, 2 X 4 and some 2 X 2's can be used to make a frame.
http://www.bing.com/images/search?q=...ls&FORM=IQFRDR
Old 01-12-2013, 07:44 PM   #3
Rewards Points: 308
I plan to frame the pieces out, but am looking for ideas of ways to fill the gaps that will be on either side of the panels.
Old 01-13-2013, 10:05 PM   #4
Rewards Points: 1,470
Look round on Craigslist for some fiberglass columns.
Find a couple, split them in half, use for decorative purposes along side the entry door and the panels, along with some decorative trim across the top.
I would paint the wall a dark color, and then hold the lattice off the wall a couple inches so it appears open as in your reference "pool house" picture.
Could turn out looking really good...
ktkelly is offline   Reply With Quote
Old 01-13-2013, 10:38 PM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 1,834
As someone who has/had some of that wood lattice in the back yard.....don't expect them to last long.
If you really want something to grow there....attach some metal bars to the block and plant some honey suckle or Jasmine.
ddawg16 is online now   Reply With Quote
Old 05-17-2013, 10:21 PM   #6
Rewards Points: 308
Decided to frame out with an arbor. Thanks!
adding on a garage debd Building & Construction 12 11-16-2011 02:03 PM
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
Adding Circuits to attached garage john8791 Electrical 1 02-10-2011 01:55 AM
Insulating garage / adding attic Red Squirrel Building & Construction 4 04-19-2010 07:33 PM
Adding on to house to build a garage. Ohioguy Building & Construction 5 02-09-2008 04:44 AM
