Adding Interior Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-15-2009, 02:22 AM   #1
adding interior wall
I want to add an interior wall in an existing room. The room already has drywall on the existing walls and ceiling. My question is, do I have to remove the ceiling drywall in order to attach the top plate of the new wall to the ceiling joists (new wall is perpendicular to the joists). Thanks for any thoughts
gillispf is offline   Reply With Quote
Old 03-15-2009, 06:38 AM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
NO not usually. mark out your wll location on the ceiling snap your caulk line across the ceiling as a referance point. locate your ceilng beams and cut and install your top plates then bottom plates, ans install your wall studs. Good luck BOB.
Old 03-17-2009, 07:34 PM   #3
Thanks for your reply, It will save me a lot of effort if I can nail my top plate through the drywall to the ceiling joists, especially since I have blown in isulation above the ceiling. Thanks!
Adding more weight to truss system... what can it hold? Sonnie Building & Construction 7 02-06-2009 09:45 PM
Adding Kitchen pass through to an existing opening? sscott0203 Remodeling 7 12-13-2008 04:17 AM
Adding new duct/Register CEbury HVAC 1 06-25-2008 11:51 AM
Adding additional landscaping steel Landscaping & Lawn Care 4 06-14-2008 02:25 AM
adding a second floor chubdo Building & Construction 11 04-16-2005 01:20 AM
