Adding Insulation To Inside Of Exterior Walls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-31-2010, 10:17 PM   #1
Question
adding insulation to inside of exterior walls
we live in New Jersey in a 50 yr old house. We have removed the old paneling in our family room which is built on a slab,( room is always cold) and are going to install drywall Th exterior walls have insulation, but i am sure we need to add to it. Its only about 2 inches (Owens Corning) and I have no idea what the R value is, and has a brown paper vapor barrier facing toward the room. From reading other posts on insulation, it seems that I add unfaced batts perpendicular to the existing insulation, but I am not sure what R value i should look for. Also I have one wall the backs onto an unheated storage room. That wall is now not insulated. It doesn't feel cold. Should I insulate it as well? Any advice would be really welcomed
thanks
daryl
darylbe is offline   Reply With Quote
Old 01-31-2010, 10:30 PM   #2
R15 I think is the highest Rvalue on a 2x4 wall
R13 is what you will normally find
2" might only be R6/7
They do not have 2" batts
You would need to take out what is there & add new
Or take out the existing batts & use 2 of those batts in each stud bay
Then buy more to fill the empty bays
Old 01-31-2010, 11:01 PM   #3
Registered User
Rewards Points: 4,914
"we live in New Jersey in a 50 yr old house." -------- R-13 is suggested for zip 070, in exterior walls.
"Its only about 2 inches (Owens Corning) and I have no idea what the R value is," ---- may be rock wool, 2" thick - R-value of 5.
"it seems that I add unfaced batts perpendicular to the existing insulation" ---- NO, only in attics- perpendicular.
Don't use two of the existing batts in a bay with both vapor retarder papers on, as suggested. Leave the front v.r. only: http://www.ornl.gov/sci/roofs+walls/...on/ins_06.html Air seal while the bays are empty.
" Should I insulate it as well?" ----- YES.
Be safe, Gary
Old 02-01-2010, 08:38 PM   #4
I would remove all the insulation have the walls spray foamed (closed cellular is R7 to R8/Inch). Min code in the northeast is R19 but its at least better than what you have.
Are the studs 2x4? If so put in new stuff
wnabcptrNH is offline   Reply With Quote
Old 02-01-2010, 09:18 PM   #5
Wink
thanks for the help consensus seems to be that i remove the existing insulation and add the largest R value i can get into the space.
thanks again
daryl
Adding insulation and storage to Cape Cod Side Attic turin39789 General DIY Discussions 5 11-08-2010 11:50 AM
Adding insulation to the underside of a high ceiling churchlady Building & Construction 6 11-17-2009 08:02 PM
How to replace insulation that fell off inside a heat pump? JMK HVAC 3 08-02-2009 10:48 AM
2x4 Exterior Wall Insulation stubits Building & Construction 4 03-19-2009 08:03 AM
Is adding insulation in attic cost effective? AllGoNoShow Building & Construction 1 12-05-2006 12:31 PM
