Adding Insulation - Getting Around In Attic - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-13-2009, 07:31 AM   #1
Adding Insulation - getting around in attic
How do you guys get around up there when you can't see the trusses?
I'm toying with the idea of putting in some more fiberglass batts, but going perpendicular, getting around by feel, and putting the batts around those perpendicular trusses seems like a long slow tedious itchy etc job.
Would blown in fiberglass make a good topper?
I'm not into cellulose.
VelvetFoot is offline   Reply With Quote
Old 11-13-2009, 10:49 AM   #2
The bottom chord is in line with the top chords, so just look up to see where to put your feet.
Since you have fiberglass batts, they must be between the trusses -- you can also look for the "joints" between the batts.
pyper is offline   Reply With Quote
Old 11-13-2009, 01:49 PM   #3
This time of year is perfect for insulating the attic, as you wont be sweating and getting fiberglass dust sticking all over you. Yes, it is a slow and tedious process, you will have to accept the fact that you are going to be itching for two days in the name of energy conservation. Our planet thanks you. Spend the time to make notches in the fiberglass where the rafters will touch the fiberglass, rather than compressing it. Don't allow the fiberglass to contact the underside of the roof deck, though, as this will block the draft from the soffit vents.
CustomBuild is offline   Reply With Quote
adding attic insulation to existing insulation strouddljs General DIY Discussions 4 11-09-2009 05:06 PM
Adding attic insulation pomelo Building & Construction 3 10-22-2009 05:19 PM
Adding insulation to only a portion of an attic? curls00 Building & Construction 22 10-27-2008 09:41 AM
Adding attic insulation and cutting soffits a DIY job? drh Roofing/Siding 15 12-31-2007 07:47 PM
Is adding insulation in attic cost effective? AllGoNoShow Building & Construction 1 12-05-2006 11:31 AM
