Adding Insulation? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-02-2008, 09:14 PM   #1
Rewards Points: 562
Adding insulation?
Last year I moved into a new home that has 8-10 inches of blown in, cellulose fiber attic insulation. I'd like to increase the insulation to the government recommended 15.5". Should I have more cellulose insulation blown in, replace the cellulose fiber with pink fiberglass batted insulation, or add Fiberglas insulation over the blown in stuff?
Thanks,
Kelly
kcrossley2 is offline   Reply With Quote
Old 12-03-2008, 05:25 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
I'd say to add more cellulose.
- Build Well -
Old 12-03-2008, 07:43 PM   #3
What can I find here?
Winchester's Avatar
Rewards Points: 150
I too would add more cellulose. If you purchase enough, may retailers will give you the machine at no charge. It's a two person job, one feeding the machine and the other up in the attic. But it's relatively a simple process. Start the furthest distance away from your attic entrance and work yourself back. Most of these machine have a wired remote that allow the person up in the attic to control the output of the machine. Allowing you to move on to the next section and/or to monitor your progress (area covered plus depth compared to the amount of bags used).
Best of luck!
Winchester is offline   Reply With Quote
Adding insulation to a low-slope roof cbeingessner Roofing/Siding 25 09-21-2010 11:01 AM
Adding insulation to only a portion of an attic? curls00 Building & Construction 22 10-27-2008 09:41 AM
adding Insulation to finished basement Mr Chips Remodeling 2 03-23-2008 10:16 AM
Adding Insulation with Re-roof Finigan Roofing/Siding 2 03-02-2008 10:25 PM
adding to existing insulation renegade Building & Construction 2 01-23-2008 10:46 PM
