Adding On A Garage - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-15-2011, 04:30 PM   #1
Rewards Points: 119
adding on a garage
We are building a garage where a car port was. What are the pros and cons concerning putting a vapor barrier under a concrete slab for the garage floor. We will be pouring over part dirt and part existing slab.
Thank for any advise
debd is offline   Reply With Quote
Old 11-15-2011, 04:42 PM   #2
Framing Contractor
You need footings and a foundation. A slab doesn't have that.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 11-15-2011, 04:47 PM   #3
Rewards Points: 119
We have just finished preparing for pouring the footings. We are wondering what to do when pouring the foundation. It will be poured over the existing carport slab plus over the dirt of the extra yardage that we are expanding to be the garage. Should a plastic vapor barrier be layed first before pouring the foundation?
Old 11-15-2011, 04:57 PM   #4
Rewards Points: 5,336
A vapor barrier should be installed under the slab.
You should not be pouring concrete over dirt. There should be a drainage later of compacted gravel.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
debd (11-16-2011)
Old 11-15-2011, 05:54 PM   #5
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
Can we assume that you do not have a plan or permits for this project?
If not then do whatever you want, I guess.
Andy.
AndyGump is offline   Reply With Quote
Old 11-15-2011, 07:19 PM   #6
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,202
where im at vapor barrier is required by code under the slab, for living spaces 2" of foam goes down as well.
the debate we've always had is does the plastic go down before or after the foam though..... if the plastic goes down first the plastic is more prone to tear... if it goes on top of the foam your gonna slip and slide all over the place when laying reinforcing mesh then placing concrete
woodworkbykirk is online now   Reply With Quote
Old 11-16-2011, 12:26 AM   #7
Rewards Points: 119
Andy.
We have permits and want to do quality work , not something that will cause problems down the line.
Old 11-16-2011, 12:32 AM   #8
AndyGump's Avatar
Rewards Points: 684
I have obtained many permits for garage conversions of all kinds. I have always had to create a set of plans showing how the construction was going to be done.
Can't get permits without them here.
Didn't you need construction docs where you are?
Andy.
Old 11-16-2011, 12:15 PM   #9
Rewards Points: 119
Andy.
Not in that detail.
Old 11-16-2011, 12:32 PM   #10
AndyGump's Avatar
Rewards Points: 684
I have found this (pouring on dirt) to be a very local issue.
Most places in LA and Orange Counties will allow this, as most of the ground around here is not silty.
We have no idea where the OP is located though.
Andy.
Old 11-16-2011, 12:44 PM   #11
Rewards Points: 119
Andy.
We are in Oregon ... lol very wet to say the least. Thanks for all the help. We will be putting down gravel and then a vapor barrier before we pour. the thing about the inspectors is that even though it doesn't have to be in the approved plans, they do check everything upon inspection.
Old 11-16-2011, 12:54 PM   #12
The thing about a detailed plan going in is that any possible issues can be dealt with before construction starts. Having the inspector tell you what you did was incorrect after the fact, costs time and money.
Ron
B. Franklin 1759
AndyGump (11-16-2011)
Old 11-16-2011, 02:03 PM   #13
Registered User
Rewards Points: 5,514
Never hurts to do research or come here for help: R506.2.3 Vapor retarder. A 6 mil (0.006 inch; 152 μm) polyethylene or approved vapor retarder with joints lapped not less than 6 inches (152 mm) shall be placed between the concrete floor slab and the base course or the prepared subgrade where no base course exists.
Exception:
The vapor retarder may be omitted:
1. From detached garages, utility buildings and other unheated accessory structures.
2. For unheated storage rooms having an area of less than 70 square feet (6.5 m2) and carports.
3. From driveways, walks, patios and other flatwork not likely to be enclosed and heated at a later date.
4. Where approved by the building official, based on local site conditions.
From: http://publicecodes.citation.com/ico...006_par004.htm
Gary
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
Adding Circuits to attached garage john8791 Electrical 1 02-10-2011 01:55 AM
Insulating garage / adding attic Red Squirrel Building & Construction 4 04-19-2010 07:33 PM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 04:57 PM
Adding on to house to build a garage. Ohioguy Building & Construction 5 02-09-2008 04:44 AM
