Old 06-27-2012, 04:55 PM   #1
Adding Foundation Wall
Is it reasonable to consider adding a foundation walls to an existing home to replace the existing aluminim siding with 3.5 to 4 inch stone siding? The existing home is approximately 1350 sq. ft. on the first floor.
WHatherill is offline   Reply With Quote
Old 06-27-2012, 05:07 PM   #2
John @ OHFS's Avatar
I believe you usually add a lentil or a ledge to the existing structure for the new brick to rest on. I don't think a new foundation wall is usually necessary, but you'll need to check with an engineer.
John @ OHFS is offline   Reply With Quote
Old 06-27-2012, 05:55 PM   #3
A LINTEL is a beam intended to span an opening in a masonry wall, so would not be used in this situation. Similarly, you can't just build 'a ledge' to sit the masonry on without being specific as to how you fix this 'ledge' to the existing structure.
We do not know the height the cladding will need to be (eg does the OP's house have tall gable walls?)
The cladding will represent a considerable extra load and will need to be properly supported. The only effective way is to extend laterally the existing footing by fixing rebar into it and casting concrete around the projecting bars. The design/specification of this is an engineer's job.
tony.g is offline   Reply With Quote
Adding tile to a bowed wall Raball Drywall & Plaster 2 08-25-2011 08:00 AM
Fill hole in foundation wall after Gas line was removed ctbfalcon Building & Construction 2 05-03-2010 09:16 AM
Foundation or Load Bearing Wall Issue? sheribaby Building & Construction 3 04-14-2010 06:07 PM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
