Adding Foundation Under A Slab. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-28-2010, 10:38 AM   #1
Adding foundation under a slab.
I am adding a addition onto the back of a garage which will have a basement. Can I put the foundation wall under the slab just were the basement will be ajoining and have the basement tie into it for support. The basement will have a 8ft ceiling height and this area is mosthly sand.
bob grube is offline   Reply With Quote
Old 01-28-2010, 10:54 AM   #2
Rewards Points: 5,336
Are you going to dig out under this slab for the basement space? If that's the case, this is not something you would(should) do.
You should break up the slab and dig your hole and install the forms for the walls.
Ron
Old 01-31-2010, 04:45 PM   #3
No I am not digging underneath the slab for the basement. I just want to add the foundation under from the edge of the slab inboard about the width of the footing and secure the slab to the foundation then butt the basement wall to the new garage foundation and figure out how to secure it. The basement wall will be poured cement. Thanks for your response.
Old 01-31-2010, 06:38 PM   #4
Licensed P.E./Home Insp
Aggie67's Avatar
Rewards Points: 826
I wouldn't, if it were my house. You may think you can excavate into the soil like a knife through cheesecake (with the walls of the exavation staying put), but that rarely happens. One rain storm, and you might find yourself building a new garage. Also, I don't see how you could properly insulate the outside of the foundation, or install drain tile. You should also tell whoever is designing the foundation that the one wall will be very close to a garage. That might play into how much soil pressure will bear against the wall.
Aggie67 is offline   Reply With Quote
Old 02-01-2010, 04:26 PM   #5
Thanks for your advise. Is there a way that this can be done without adding a foundation under the entire garage?
Old 02-01-2010, 05:28 PM   #6
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 126
I'm no engineer but I'd be worried that the garage may want to "tip over" right against the new structure. The ground pressure of the weight will make it so the wall of the basement needs to take lot of side/diagonal pressure compared to the other side of the garage.
Then again I'm no expert. I'd be curious to see how this would be handled by a pro. I'm sure it's been done before, but there is probably a very specific process to it.
Old 02-01-2010, 07:11 PM   #7
Aggie67's Avatar
Rewards Points: 826
Now that I see a rendition on screen, I'm going to keep my nose out of this. I have a firm I call when we need to do things like that. I stay away from that kind of work. A little too risky.
My recommendation is to call in an unbiased professional to come up with a design and construction scheme, and have some folks bid it. Leave all the risk in their lap.
Old 02-01-2010, 08:36 PM   #8
Wire Chewer
Rewards Points: 126
Keep in mind my pic might be wrong, I'm just making some assumptions as to what seems would make sense from a physics point of view.
Old 02-02-2010, 09:08 AM   #9
your picture is correct except it is missing the footing under the slab that the basement wall will butt up against. I had several builders tell me it can be done but it's hard to get a answer as to how and how much.
Old 02-02-2010, 11:08 AM   #10
Contractors are more likely to give estimates if they're given a set of blueprints to work from. It shows the homeowner has officially started the process and has himself invested in the project.
Estimates take time and nobody wants to waste time on vague drawings and descriptions that might get more involved(pricier) once plans get drawn up based on an experienced, professional eye.
Ron
Extending slab foundation for bigger bathroom newimaging Building & Construction 1 07-02-2009 10:27 PM
Is this a high quote? Price of a slab foundation pauls Building & Construction 8 10-29-2008 07:49 AM
Darn. A leak in my main supply from street, Galvanized. In foundation under slab? twilightcall Plumbing 2 07-31-2008 12:22 AM
I need help Re: Poured Slab Foundation - Moved to Plumbing alextina Plumbing 6 04-19-2007 04:35 PM
slab foundation jorguez1167 Building & Construction 2 06-27-2006 11:42 AM
