Adding Fibers To Concrete Mix - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-28-2008, 05:06 PM   #1
Rewards Points: 1,062
adding fibers to concrete mix
someone suggested to me that adding fibers to concrete mix prevents subsequent cracking.
was wondering if there are any downsides to doing this ?
thx,
- a -
Old 01-28-2008, 05:30 PM   #2
Rewards Points: 6,652
Downside, having a bunch of the fibers spilt on the ground. It is supposed to add strength to the concrete without putting in Re-Bar.
Old 01-28-2008, 05:35 PM   #3
thx,
- a -
How big of an area and what kind of project are you asking about?
jerryh3 is offline   Reply With Quote
Old 01-28-2008, 05:40 PM   #4
800 sq ft basement. most of it has been paved although i will redo some (did not use styrofoam insulation under). but i like using remash, if remash does the same as fibers, i will just do that.
thx,
- a -
Old 01-28-2008, 06:06 PM   #5
concretemasonry's Avatar
Rewards Points: 2,566
Fibers are never a substitute for wire mesh - PERIOD!!!!
Fibers do not increase the compressive strength of concrete.
Fibers can help with micro-cracking.
If you have no experience finishing fibers don't do it!
If you are thinking of adding fibers to a mix you are making, don't do it - A recipe for a problems because of the lack of knowledge of proper mixing time to make them work.
concretemasonry is offline   Reply With Quote
Old 01-28-2008, 06:22 PM   #6
Question
10-4
you convinced me.
Q: does remash prevent micro-cracking ?
the portion of the floor that i paved and will redo using nothing but concrete and gravel (stupid beginner's mistake) already has some cracks. the rest where i did use reinforcement and insulation is not cracked anywhere.
thx,
- a -
Old 01-29-2008, 04:19 PM   #7
Rewards Points: 5,336
What's remash? Is that a local term for wire mesh?
Ron
Old 01-29-2008, 11:13 PM   #8
Rewards Points: 1,220
Second stage on your way to moonshine out in the hills....
Tscarborough is offline   Reply With Quote
Old 01-29-2008, 11:16 PM   #9
Talking
Ron
yes i thought that was the term, ha ha. same thing.
Old 01-29-2008, 11:17 PM   #10
Talking
this is brilliant took me a while to get it though. you must be from franklin county, VA.
Old 01-29-2008, 11:50 PM   #11
general contractor
A.W.Davis's Avatar
thx,
- a -
If you have expansion joints in your concrete, the cracks typically follow the joint(s). I would never substitute rebar for the fibermesh unless the area is too shallow for rebar. We did a job where we repaired some rotted cantilevered breezeways in a condo complex and repoured without rebar and used fibermesh in our pour. We made expansion joints and used sikaflex in the joints to help control the cracks. There was never any cracking of the concrete down the line.
A.W.Davis is offline   Reply With Quote
Old 01-29-2008, 11:56 PM   #12
ICF Construction
I'm standing with ConcreteMasonary on this one.
just to add to it, if you are not finishing the top of the floor with anything, the concrete is fuzzy until you wear it off by walking or moving stuff on it, if you use metal mesh pieces than I have seen rust stains all over the floor...that does wonders if you acid stain the floor at a later date.
Chris
Chris Johnson is offline   Reply With Quote
Old 01-30-2008, 12:04 AM   #13
general contractor
A.W.Davis's Avatar
Originally Posted by Chris Johnson View Post
I'm standing with ConcreteMasonary on this one..
That also depends on the situation. You DO NOT want to use wire mesh,rebar or wire gridding on a cantilevered wooden structure such as a breezeway or a flat balcony because the material will pierce the bituthene underlayment and eventually cause a leak.
Filling sunken living room w/ concrete Q's phil. Building & Construction 5 07-10-2009 01:03 PM
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 10:38 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 02:32 PM
stone veneer formula tom1st Landscaping & Lawn Care 1 07-08-2006 05:48 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 11:27 PM
