Adding A Downspout To Existing Gutters - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-03-2011, 06:58 AM   #1
Adding a downspout to existing gutters
I have a gutter going from my garage to my porch. It traverses about 12 feet back from the front corner of the garage, then turns (90 degrees) and goes about 8 feet across the front porch. There is only one downspout at the front garage corner. During heavy rains, there is a steady stream of water overflowing near the front porch. So, I'd like to add a downspout in that area.
I've seen (at the big box stores) pieces for adding downspouts. What's the best way to secure it to the existing gutters? I know there are issues with seams, any tips to reduce this?
Thanks!
koz123 is offline   Reply With Quote
Old 05-03-2011, 07:22 AM   #2
Rewards Points: 50
I assume you've checked the gutter and down spouts for blockages. Are the gutters still sloped properly or are they sagging or pulled out from the fascia where the water overflows? Maybe you just need a larger downspout at the existing location?
daveb1 is offline   Reply With Quote
Old 05-03-2011, 07:28 AM   #3
Willing to listen
Rewards Points: 223
Had a similar issue, and gutters were all being replaced due to hail damage so an extra downspout was added which did the trick, but I did not do the work.
Anytime you are doing gutters you need to use a seam sealer that's like caulk at any joints if you want it to be leak free. Other than that it's all sheet metal screws and straps putting it all together....not sure if that is what you were asking. Good luck.
Done That is offline   Reply With Quote
Old 05-03-2011, 09:17 AM   #4
Rewards Points: 5,336
I use rivets to attach the downspout piece to the gutter and seam sealer under the lip.
Ron
Adding 2 more lights to existing light BCH_COLIN Electrical 7 01-24-2011 11:04 AM
Helping adding a light to an existing 3 way circuit. McSooner Electrical 4 12-03-2010 09:54 AM
adding attic insulation to existing insulation strouddljs General DIY Discussions 4 11-09-2009 05:06 PM
Adding a stand alone wood furnace to existing duct work vtboy51 HVAC 1 04-01-2009 02:19 PM
Electrical Question - adding a 3 way switch to existing Light Marcus23 Electrical 5 10-11-2008 08:52 AM
