Old 06-02-2010, 10:07 PM   #1
Adding a deck
I am taking off my 4 x 6 deck to pour a patio (bigger than the deck). any way i want to reattach the deck once the underside is leveled and poured.
Can the 2 out side legs just sit on the cement patio? I dont want to have them stick through the cement patio.
any help is welcome thanks.
luweee is offline   Reply With Quote
Old 06-02-2010, 10:11 PM   #2
Adding a deck
ANyone Know whats code to put outdoor electrical under patio being poured.
i know there are local codes. but whats national or maybe other city codes for this?
I was thinking running 1 inch pvc under the patio before pouring and capping off on each end. This is for FUTURE use.
thanks people you are always helpful.
Old 06-03-2010, 10:12 AM   #3
Xtreme DIY'r
Adding a deck
Where are you located ?
Old 06-03-2010, 09:28 PM   #4
jlhaslip's Avatar
Adding a deck
Around here, the conduit for electrical would need to be 18 inches below grade,protected by pressure treated lumber, and marker tape.
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 06-03-2010, 09:45 PM   #5
Xtreme DIY'r
Adding a deck
Protected by concrete is OK @much less then 18" if its the entire run
Or the part not under concrete has to be deeper
Need to know your location
Help with adding a roof over my deck robdec Roofing/Siding 14 11-07-2009 10:08 PM
Adding Stairs To A Deck WBNC Building & Construction 19 08-06-2009 10:54 AM
Adding a Deck Gate briancs1981 Building & Construction 3 07-09-2009 05:24 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
Adding on to my mothers deck question. justariot Carpentry 6 03-15-2009 08:09 PM
