-   -   Adding a deck (http://www.diychatroom.com/f19/adding-deck-72688/)
luweee 06-02-2010 09:07 PM
Adding a deck
I am taking off my 4 x 6 deck to pour a patio (bigger than the deck). any way i want to reattach the deck once the underside is leveled and poured.
Can the 2 out side legs just sit on the cement patio? I dont want to have them stick through the cement patio.
any help is welcome thanks.
luweee 06-02-2010 09:11 PM
Want to run electrical under patio before pouring it.
ANyone Know whats code to put outdoor electrical under patio being poured.
i know there are local codes. but whats national or maybe other city codes for this?
I was thinking running 1 inch pvc under the patio before pouring and capping off on each end. This is for FUTURE use.
thanks people you are always helpful.
Scuba_Dave 06-03-2010 09:12 AM
Where are you located ?
jlhaslip 06-03-2010 08:28 PM
Around here, the conduit for electrical would need to be 18 inches below grade,protected by pressure treated lumber, and marker tape.
Scuba_Dave 06-03-2010 08:45 PM
Protected by concrete is OK @much less then 18" if its the entire run
Or the part not under concrete has to be deeper
Need to know your location
