Old 07-02-2008, 10:20 PM   #1
Weekender
adding to concrete steps
I want to make the entry steps to my front door wider by about 2 feet. They are brick and I believe there is a concrete base. Is there any way to add to the current width without tearing out the whole thing and starting over?
I wonder if taking the brick off, then sinking some bolts into the stairs to bind a new pour on the side would work?
I am unsure what is under the brick in the 1967 house in Virginia.
jmoser1@woh.rr.com is offline   Reply With Quote
Old 07-02-2008, 11:29 PM   #2
Moderator
Termite's Avatar
You're on track with the idea of bolts to tie the two together. I'd take it a little further. Get some 1/2" x 12" all-thread and some concrete epoxy. Drill a 1/2" hole 6" deep, blow the dust out of it, squirt expoxy in, coat the rod, and drive it home. I'd do a couple at each tread.
Once the epoxy sets, just form the new concrete up and pour right around the rods.
Concrete steps Shadowchase Building & Construction 5 07-04-2008 07:01 PM
deck header over concrete steps and other deck questions bobcatnj Building & Construction 6 05-09-2008 03:54 PM
Concrete steps - Dressing up larryr20 Landscaping & Lawn Care 1 08-23-2006 02:24 PM
