Adding A Concrete Curb - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-24-2013, 07:01 PM   #1
Rewards Points: 518
Adding a concrete curb
What are the advantages/disadvantages of adding a poured concrete curb to an already existing slab that will be used for a garage?
n0c7 is offline   Reply With Quote
Old 02-24-2013, 07:14 PM   #2
For 1 it is code, 2 it will keep the water away from the finish material and prevent rot, 3 it just looks better.
JonM is offline   Reply With Quote
Old 02-25-2013, 12:32 AM   #3
Rewards Points: 1,016
I see you are in Canada. Does that existing slab have adequate footing to the frost line and to support a garage built on it?
____________
Vince
Old 02-25-2013, 04:20 PM   #4
Concrete & Masonry
Rewards Points: 468
More than likely, it's a "floating slab", which is allowed by code in most of the US, as well as much of Canada, at least from what I can tell.
Every slab would ideally have a curb around the perimeter to keep the non-treated lumber at least 6" above the grade/ground........
jomama45 is offline   Reply With Quote
Old 02-25-2013, 11:56 PM   #5
Rewards Points: 518
jomama45 is right - it's a floating slab, built up to and graded to 6" from the ground. I want to add the curb because the garage will be heated so I'm hoping for easier cleanup.
Since I would be adding this on top of the slab, will the "seam" between the existing concrete and the new curb be a weak spot for water to get in and eat away over the years?
Old 02-26-2013, 06:07 AM   #6
Rewards Points: 4,442
its called a ' cold joint ' & yes, it will be a weak spot for water to get in UNLESS you coat the exterior w/suitable waterproofing compound such as sonneborn's sonolastic or comparable product,,, NOT avail in apron/vest stores however they do have roofing cements
Old 02-27-2013, 10:14 AM   #7
Rewards Points: 518
Is it basically like applying a caulk to the seam?
Old 02-27-2013, 10:34 AM   #8
Roofmaster
Rewards Points: 2,172
You are adding the curb because in a previous post you admitted to pouring the slab with no curb. Cmon now, fess up. You can, and should add a level curb If it were me, I would hammer drill holes around the perimeter about every three feet to receive No 4 (1/2") rebar that sticks up about 7 inches. Form by Riping 2 x 12 to the slope of your floor so the top is LEVEL. Make the curb about 8 inches wide. Have someone make up a Z metal pan that has a 2 inch upturned lip inside, goes across under the curb, and turns down the outside of the slab about 2.5 inches with a drip. cut holes for the rebar and install pan by setting in urethane sealant NP1 is good, as is Bostic Chem calk 900. Ring rebar. Set that pan working fro low to high. Door to back of garage.
Put skewback on top of form to form 45 at top. pour curb with 3400 PSI concrete, and tap all around with hammer to remove honeycombs. Trowel top smooth. Use redhead anchors to secure PT sole plate over termite shield.
Old 02-27-2013, 04:19 PM   #9
Rewards Points: 518
I bought a spec house, not much say when the work was already done. If I could have done things differently, I would have gone with a much larger pad than 20x22 and had the curb integrated. Thanks for the detailed reply.
Bamboo on modified concrete pad jhanson Flooring 0 10-08-2011 12:58 PM
High Rise Building methods - US versus Oz - Steel versus Concrete Jado Off Topic 17 09-15-2011 09:47 PM
Tips For Pouring Concrete? Root issues? Thoughts? kronic24601 Building & Construction 5 02-14-2011 07:52 AM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 05:53 PM
adding to concrete steps jmoser1@woh.rr.com Building & Construction 1 07-02-2008 11:29 PM
