Adding Bullnose To Existing Staircase - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-25-2013, 10:57 AM   #1
adding bullnose to existing staircase
Hi. I'm renovating some existing stairs: removed old carpet and wood paneling, adding drywall and carpet. I'd like to add a bullnose to each step before the carpet goes in. The existing tread on the stair is solid, 1.5" or 2" thick, not plywood. I know the added bullnose will have to take a lot of pressure so I'd love any advice.
My plan is to add a 3/4'" x 3/4" strip to the edge of each tread with a screw every few inches and construction adhesive. Does this seem like enough to hold it in place? Also, what type of wood should I use? Something hard like oak or just whatever standard product is available, probably cedar where I live. Vancouver.
Thanks very much,
c.
cchobbs is offline   Reply With Quote
adding new wired smoke detectors to existing wired smoke detectors CapeCod153 Electrical 9 06-21-2012 05:03 AM
Adding Light to Existing Circuit NEWJACK Electrical 2 05-11-2012 12:09 PM
Adding a downspout to existing gutters koz123 Building & Construction 3 05-03-2011 09:17 AM
adding to existing red/white mixed oak floors - What grade do I look for? KAdams4458 Flooring 4 02-18-2011 12:10 PM
Adding new register via tee off existing register tpanc13 HVAC 12 06-30-2010 12:04 PM
