Adding Attic Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-17-2011, 02:21 PM   #1
I have a layer of rock wool currently in my attic up to the top of the joists. It has no vapor barrier down as well. Should I use faced or unfaced rols?
Bob58 is offline   Reply With Quote
Old 02-17-2011, 10:32 PM   #2
Registered User
Rewards Points: 526
Where are you located?
Gary
Attic insulation and soffit venting zacker Building & Construction 1 07-15-2010 10:17 PM
Adding Insulation - getting around in attic VelvetFoot Building & Construction 2 11-13-2009 01:49 PM
Idea for attic insulation baffles. What are your thoughts? Ininkus Building & Construction 8 02-26-2009 12:46 PM
Adding insulation to only a portion of an attic? curls00 Building & Construction 22 10-27-2008 09:41 AM
Attic Insulation Quote...what do you think? mitchel Roofing/Siding 15 08-06-2008 07:10 AM
